Feature for creation of a new constraint which defines a horizontal distance between two points. More...
#include <SketchPlugin_ConstraintDistanceHorizontal.h>
| virtual SKETCHPLUGIN_EXPORT const std::string & | getKind () |
| SketchPlugin_ConstraintDistanceHorizontal () | |
| virtual SKETCHPLUGIN_EXPORT void | execute () |
| virtual SKETCHPLUGIN_EXPORT void | initAttributes () |
| virtual SKETCHPLUGIN_EXPORT AISObjectPtr | getAISObject (AISObjectPtr thePrevious) |
| Returns the AIS preview. More... | |
| virtual SKETCHPLUGIN_EXPORT void | attributeChanged (const std::string &theID) |
| void | setNumericValue (const double theValue) override |
| Set numeric value to attribute DISTANCE_VALUE_ID() More... | |
| double | getNumericValue () override |
| Get numeric value of attribute DISTANCE_VALUE_ID() More... | |
| virtual void | colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault) |
| virtual bool | isZeroValueAllowed () |
| Get if a constraint is able to have a zero numeric value. More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true if the feature is a copy of other feature. More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| virtual bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| std::wstring | name () |
| Distance constraint kind. More... | |
| static const std::string & | LOCATION_TYPE_ID () |
| attribute name of dimension location type More... | |
| static const std::string & | DISTANCE_VALUE_ID () |
| attribute name of the distance value shown to the user More... | |
| static const std::string & | NEGATIVE_TYPE_ID () |
| attribute name of the sign of distance More... | |
| static const std::string & | SIGNED () |
| Shows whether the point-line distance should keep its sign. More... | |
| static const std::string & | DIRECTION_ID () |
| The direction from the first object to the second. More... | |
| static const std::string & | VALUE () |
| The value parameter for the constraint. More... | |
| static const std::string & | FLYOUT_VALUE_PNT () |
| The 2D value parameter for the constraint. More... | |
| static const std::string & | CONSTRAINT_ACTIVE () |
| State of constraint - Active - true, Suppressed - false. More... | |
| static const std::string & | ENTITY_A () |
| First entity for the constraint. More... | |
| static const std::string & | ENTITY_B () |
| Second entity for the constraint. More... | |
| static const std::string & | ENTITY_C () |
| Third entity for the constraint. More... | |
| static const std::string & | ENTITY_D () |
| Fourth entity for the constraint. More... | |
| static const std::string & | ATTRIBUTE (const int theNumber) |
| List of constraint attributes. More... | |
| virtual double | calculateCurrentDistance () |
| Returns the current distance between the feature attributes. More... | |
| virtual void | updateFlyoutPoint () |
| Update flyout point. More... | |
| bool | areAttributesInitialized () |
| Check the attributes related to distanced points/features are initialized. More... | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
Protected Attributes | |
| double | myValue |
| bool | myValueUpdate |
| bool | myFlyoutUpdate |
| to avoid cyclic dependencies on automatic updates of flyout point More... | |
This constraint has three attributes: SketchPlugin_Constraint::VALUE(), SketchPlugin_Constraint::ENTITY_A() and SketchPlugin_Constraint::ENTITY_B()
| SketchPlugin_ConstraintDistanceHorizontal::SketchPlugin_ConstraintDistanceHorizontal | ( | ) |
inlinestatic |
inlinevirtual |
Reimplemented from SketchPlugin_ConstraintDistance.
protectedvirtual |
Implements SketchPlugin_ConstraintDistanceAlongDir.
protectedvirtual |
inlinestaticinherited |
overridevirtualinherited |
| theValue | new set value |
Reimplemented from SketchPlugin_Constraint.
inlineoverridevirtualinherited |
To change distance value from zero to non-zero correctly.
protectedinherited |
inlinevirtualinherited |
Reimplemented in SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_Point, and SketchPlugin_Projection.
inlineprotectedinherited |
inlineinherited |
Implements ModelAPI_Object.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
