FeaturesPlugin_Intersection Class Reference
Intersection feature takes a list of shapes as objects and list of shapes as tools. More...
#include <FeaturesPlugin_Intersection.h>
Inheritance diagram for FeaturesPlugin_Intersection:
virtual void execute ()
 Executes feature. More...
 FeaturesPlugin_Intersection ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & OBJECT_LIST_ID ()
 Attribute name of objects. More...
static const std::string & USE_FUZZY_ID ()
 Attribute name of use fuzzy parameter. More...
static const std::string & FUZZY_PARAM_ID ()
 Attribute name of fuzzy parameter. More...
static std::string group ()
void initVersion (const std::string &theVersion, const std::shared_ptr< ModelAPI_Attribute > theObjectsAttr=std::shared_ptr< ModelAPI_Attribute >(), const std::shared_ptr< ModelAPI_Attribute > theToolsAttr=std::shared_ptr< ModelAPI_Attribute >())
 Initialize version field of the Boolean feature. More...
bool processAttribute (const std::string &theAttributeName, GeomAPI_ShapeHierarchy &theObjects, ListOfShape &thePlanesList)
 Process SelectionList attribute and fill the objects hierarchy. More...
bool processObject (const GeomAlgoAPI_Tools::BOPType theBooleanType, const GeomShapePtr &theObject, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr())
 Perform Boolean operation of the object with the tools. More...
bool processCompsolid (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompsolidHierarchy, const GeomShapePtr &theCompsolid, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr())
 Perform Boolean operation of the Compsolid with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More...
bool processCompound (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompoundHierarchy, const GeomShapePtr &theCompound, const ListOfShape &theTools, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr())
 Perform Boolean operation of the Compound with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More...
GeomShapePtr keepUnusedSubsOfCompound (const GeomShapePtr &theResult, const GeomAPI_ShapeHierarchy &theObjectsHierarchy, const GeomAPI_ShapeHierarchy &theToolsHierarchy, std::shared_ptr< GeomAlgoAPI_MakeShapeList > theMakeShapeList)
 Process unused sub-shapes of compounds. More...
static const std::string & BOP_VERSION_9_4 ()
static void resizePlanes (const ListOfShape &theObjects, ListOfShape &thePlanes, std::shared_ptr< GeomAlgoAPI_MakeShapeList > &theMakeShapeList)
 Resize planes to fit them to the bounding box of the given lins of objects. More...
The types of objects and tools may be different: whole objects, compsoilds, solids, shells, faces or edges. The result is less than the minimal dimension from pair of intersection: for two solids or two faces it is wire, for the edge and face it is vertex, etc.
◆ FeaturesPlugin_Intersection()
FeaturesPlugin_Intersection::FeaturesPlugin_Intersection ( )
◆ ID()
static const std::string & FeaturesPlugin_Intersection::ID ( )
inlinestatic
Feature kind.
◆ OBJECT_LIST_ID()
static const std::string & FeaturesPlugin_Intersection::OBJECT_LIST_ID ( )
inlinestatic
◆ USE_FUZZY_ID()
static const std::string & FeaturesPlugin_Intersection::USE_FUZZY_ID ( )
inlinestatic
◆ FUZZY_PARAM_ID()
static const std::string & FeaturesPlugin_Intersection::FUZZY_PARAM_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_Intersection::getKind ( )
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_Intersection::execute ( )
Executes feature.
◆ initAttributes()
void FeaturesPlugin_Intersection::initAttributes ( )
Implements ModelAPI_Object.
◆ initVersion()
void FeaturesPlugin_VersionedBoolean::initVersion ( const std::string &  theVersion,
const std::shared_ptr< ModelAPI_Attribute >  theObjectsAttr = std::shared_ptr<ModelAPI_Attribute>(),
const std::shared_ptr< ModelAPI_Attribute >  theToolsAttr = std::shared_ptr<ModelAPI_Attribute>()
The version is initialized for newly created features, not read from previously stored document.
◆ processAttribute()
bool FeaturesPlugin_VersionedBoolean::processAttribute ( const std::string &  theAttributeName,
GeomAPI_ShapeHierarchy &  theObjects,
ListOfShape &  thePlanesList
◆ processObject()
bool FeaturesPlugin_VersionedBoolean::processObject ( const GeomAlgoAPI_Tools::BOPType  theBooleanType,
const GeomShapePtr &  theObject,
const ListOfShape &  theTools,
const ListOfShape &  thePlanes,
int &  theResultIndex,
std::vector< ModelAPI_Tools::ResultBaseAlgo > &  theResultBaseAlgoList,
ListOfShape &  theResultShapesList,
GeomShapePtr  theResulCompound = GeomShapePtr()
false if something went wrong
◆ processCompsolid()
bool FeaturesPlugin_VersionedBoolean::processCompsolid ( const GeomAlgoAPI_Tools::BOPType  theBooleanType,
GeomAPI_ShapeHierarchy &  theCompsolidHierarchy,
const GeomShapePtr &  theCompsolid,
◆ processCompound()
bool FeaturesPlugin_VersionedBoolean::processCompound ( const GeomAlgoAPI_Tools::BOPType  theBooleanType,
GeomAPI_ShapeHierarchy &  theCompoundHierarchy,
const GeomShapePtr &  theCompound,
◆ resizePlanes()
void FeaturesPlugin_VersionedBoolean::resizePlanes ( const ListOfShape &  theObjects,
std::shared_ptr< GeomAlgoAPI_MakeShapeList > &  theMakeShapeList
staticprotectedinherited
◆ keepUnusedSubsOfCompound()
GeomShapePtr FeaturesPlugin_VersionedBoolean::keepUnusedSubsOfCompound ( const GeomShapePtr &  theResult,
const GeomAPI_ShapeHierarchy &  theObjectsHierarchy,
const GeomAPI_ShapeHierarchy &  theToolsHierarchy,
Keep the compound hierarchy, but merge top-level compounds into a single compound and add the result of the FUSE operation.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
