SketchPlugin_ConstraintDistanceVertical Class Reference
Feature for creation of a new constraint which defines a vertical distance between two points. More...
#include <SketchPlugin_ConstraintDistanceVertical.h>
Inheritance diagram for SketchPlugin_ConstraintDistanceVertical:
virtual SKETCHPLUGIN_EXPORT const std::string & getKind ()
 SketchPlugin_ConstraintDistanceVertical ()
virtual SKETCHPLUGIN_EXPORT void execute ()
virtual SKETCHPLUGIN_EXPORT void initAttributes ()
virtual SKETCHPLUGIN_EXPORT AISObjectPtr getAISObject (AISObjectPtr thePrevious)
virtual SKETCHPLUGIN_EXPORT void attributeChanged (const std::string &theID)
void setNumericValue (const double theValue) override
 Set numeric value to attribute DISTANCE_VALUE_ID() More...
double getNumericValue () override
 Get numeric value of attribute DISTANCE_VALUE_ID() More...
virtual void colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault)
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Distance constraint kind. More...
static const std::string & LOCATION_TYPE_ID ()
 attribute name of dimension location type More...
static const std::string & DISTANCE_VALUE_ID ()
 attribute name of the distance value shown to the user More...
static const std::string & NEGATIVE_TYPE_ID ()
 attribute name of the sign of distance More...
static const std::string & SIGNED ()
 Shows whether the point-line distance should keep its sign. More...
static const std::string & DIRECTION_ID ()
 The direction from the first object to the second. More...
static std::string group ()
virtual double calculateCurrentDistance ()
 Returns the current distance between the feature attributes. More...
virtual void updateFlyoutPoint ()
 Update flyout point. More...
bool areAttributesInitialized ()
 Check the attributes related to distanced points/features are initialized. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
double myValue
bool myValueUpdate
bool myFlyoutUpdate
 to avoid cyclic dependencies on automatic updates of flyout point More...
This constraint has three attributes: SketchPlugin_Constraint::VALUE(), SketchPlugin_Constraint::ENTITY_A() and SketchPlugin_Constraint::ENTITY_B()
◆ SketchPlugin_ConstraintDistanceVertical()
SketchPlugin_ConstraintDistanceVertical::SketchPlugin_ConstraintDistanceVertical ( )
◆ ID()
static const std::string & SketchPlugin_ConstraintDistanceVertical::ID ( )
inlinestatic
◆ getKind()
virtual SKETCHPLUGIN_EXPORT const std::string & SketchPlugin_ConstraintDistanceVertical::getKind ( )
Reimplemented from SketchPlugin_ConstraintDistance.
◆ calculateCurrentDistance()
double SketchPlugin_ConstraintDistanceVertical::calculateCurrentDistance ( )
Implements SketchPlugin_ConstraintDistanceAlongDir.
◆ updateFlyoutPoint()
void SketchPlugin_ConstraintDistanceVertical::updateFlyoutPoint ( )
◆ LOCATION_TYPE_ID()
static const std::string & SketchPlugin_ConstraintDistanceAlongDir::LOCATION_TYPE_ID ( )
inlinestaticinherited
◆ DISTANCE_VALUE_ID()
static const std::string & SketchPlugin_ConstraintDistanceAlongDir::DISTANCE_VALUE_ID ( )
◆ NEGATIVE_TYPE_ID()
static const std::string & SketchPlugin_ConstraintDistanceAlongDir::NEGATIVE_TYPE_ID ( )
◆ execute()
void SketchPlugin_ConstraintDistanceAlongDir::execute ( )
◆ initAttributes()
void SketchPlugin_ConstraintDistanceAlongDir::initAttributes ( )
◆ getAISObject()
AISObjectPtr SketchPlugin_ConstraintDistanceAlongDir::getAISObject ( AISObjectPtr  thePrevious)
◆ attributeChanged()
void SketchPlugin_ConstraintDistanceAlongDir::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ setNumericValue()
void SketchPlugin_ConstraintDistanceAlongDir::setNumericValue ( const double  theValue)
overridevirtualinherited
theValuenew set value
Reimplemented from SketchPlugin_Constraint.
◆ getNumericValue()
double SketchPlugin_ConstraintDistanceAlongDir::getNumericValue ( )
inlineoverridevirtualinherited
◆ SIGNED()
static const std::string & SketchPlugin_ConstraintDistance::SIGNED ( )
◆ DIRECTION_ID()
static const std::string & SketchPlugin_ConstraintDistance::DIRECTION_ID ( )
To change distance value from zero to non-zero correctly.
◆ colorConfigInfo()
void SketchPlugin_ConstraintDistance::colorConfigInfo ( std::string &  theSection,
std::string &  theName,
std::string &  theDefault
Returns the parameters of color definition in the resources config manager.
◆ areAttributesInitialized()
bool SketchPlugin_ConstraintDistance::areAttributesInitialized ( )
◆ VALUE()
◆ FLYOUT_VALUE_PNT()
◆ CONSTRAINT_ACTIVE()
◆ ENTITY_A()
◆ ENTITY_B()
◆ ENTITY_C()
◆ ENTITY_D()
◆ ATTRIBUTE()
◆ isZeroValueAllowed()
inlinevirtualinherited
◆ isInHistory()
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
Implements ModelAPI_Object.
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
◆ myFlyoutUpdate
bool SketchPlugin_ConstraintDistance::myFlyoutUpdate
