Feature for rotation objects around the axis. More...
#include <FeaturesPlugin_Rotation.h>
| virtual FEATURESPLUGIN_EXPORT const std::string & | getKind () |
| virtual FEATURESPLUGIN_EXPORT void | execute () |
| virtual FEATURESPLUGIN_EXPORT void | initAttributes () |
| FeaturesPlugin_Rotation () | |
| std::wstring | name () |
| Rotation kind. More... | |
| static const std::string & | CREATION_METHOD () |
| Attribute name for creation method. More... | |
| static const std::string & | CREATION_METHOD_BY_ANGLE () |
| Attribute name for creation method "ByAxisAndAngle". More... | |
| static const std::string & | CREATION_METHOD_BY_THREE_POINTS () |
| Attribute name for creation method "ByThreePoints". More... | |
| static const std::string & | OBJECTS_LIST_ID () |
| Attribute name of referenced objects. More... | |
| static const std::string & | AXIS_OBJECT_ID () |
| Attribute name of an axis. More... | |
| static const std::string & | ANGLE_ID () |
| Attribute name of angle. More... | |
| static const std::string & | CENTER_POINT_ID () |
| Attribute name of a center point. More... | |
| static const std::string & | START_POINT_ID () |
| static const std::string & | END_POINT_ID () |
| FeaturesPlugin_Rotation::FeaturesPlugin_Rotation | ( | ) |
inlinestatic |
Rotation kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
