FeaturesPlugin_Rotation.h
20#ifndef FeaturesPlugin_Rotation_H_
21#define FeaturesPlugin_Rotation_H_
23#include <FeaturesPlugin.h>
24
26
27class GeomAPI_Trsf;
28
33{
34 public:
36 inline static const std::string& ID()
37 {
38 static const std::string MY_ROTATION_ID("Rotation");
39 return MY_ROTATION_ID;
40 }
41
43 inline static const std::string& CREATION_METHOD()
44 {
45 static const std::string MY_CREATION_METHOD_ID("CreationMethod");
46 return MY_CREATION_METHOD_ID;
47 }
48
50 inline static const std::string& CREATION_METHOD_BY_ANGLE()
51 {
52 static const std::string MY_CREATION_METHOD_ID("ByAxisAndAngle");
53 return MY_CREATION_METHOD_ID;
54 }
55
57 inline static const std::string& CREATION_METHOD_BY_THREE_POINTS()
58 {
59 static const std::string MY_CREATION_METHOD_ID("ByThreePoints");
60 return MY_CREATION_METHOD_ID;
61 }
62
64 inline static const std::string& OBJECTS_LIST_ID()
65 {
66 static const std::string MY_OBJECTS_LIST_ID("main_objects");
67 return MY_OBJECTS_LIST_ID;
68 }
69
71 inline static const std::string& AXIS_OBJECT_ID()
72 {
73 static const std::string MY_AXIS_OBJECT_ID("axis_object");
74 return MY_AXIS_OBJECT_ID;
75 }
76
78 inline static const std::string& ANGLE_ID()
79 {
80 static const std::string MY_ANGLE_ID("angle");
81 return MY_ANGLE_ID;
82 }
83
85 inline static const std::string& CENTER_POINT_ID()
86 {
87 static const std::string MY_CENTER_POINT_ID("center_point");
88 return MY_CENTER_POINT_ID;
89 }
90
92 inline static const std::string& START_POINT_ID()
93 {
94 static const std::string MY_START_POINT_ID("start_point");
95 return MY_START_POINT_ID;
96 }
97
99 inline static const std::string& END_POINT_ID()
100 {
101 static const std::string MY_END_POINT_ID("end_point");
102 return MY_END_POINT_ID;
103 }
104
106 FEATURESPLUGIN_EXPORT virtual const std::string& getKind()
107 {
108 static std::string MY_KIND = FeaturesPlugin_Rotation::ID();
109 return MY_KIND;
110 }
111
113 FEATURESPLUGIN_EXPORT virtual void execute();
114
116 FEATURESPLUGIN_EXPORT virtual void initAttributes();
117
120
121private:
123 std::shared_ptr<GeomAPI_Trsf> rotationByAxisAndAngle();
124
126 std::shared_ptr<GeomAPI_Trsf> rotationByThreePoints();
127
129 void performRotation(const std::shared_ptr<GeomAPI_Trsf>& theTrsf);
130};
131
132#endif
Feature for rotation objects around the axis.
Definition: FeaturesPlugin_Rotation.h:33
virtual FEATURESPLUGIN_EXPORT void initAttributes()
Definition: FeaturesPlugin_Rotation.cpp:51
virtual FEATURESPLUGIN_EXPORT void execute()
Definition: FeaturesPlugin_Rotation.cpp:78
static const std::string & CREATION_METHOD_BY_THREE_POINTS()
Attribute name for creation method "ByThreePoints".
Definition: FeaturesPlugin_Rotation.h:57
FeaturesPlugin_Rotation()
Definition: FeaturesPlugin_Rotation.cpp:46
static const std::string & START_POINT_ID()
Attribute name of a center point.
Definition: FeaturesPlugin_Rotation.h:92
static const std::string & CREATION_METHOD_BY_ANGLE()
Attribute name for creation method "ByAxisAndAngle".
Definition: FeaturesPlugin_Rotation.h:50
Attribute name of referenced objects.
Definition: FeaturesPlugin_Rotation.h:64
static const std::string & END_POINT_ID()
Definition: FeaturesPlugin_Rotation.h:99
static const std::string & AXIS_OBJECT_ID()
Attribute name of an axis.
Definition: FeaturesPlugin_Rotation.h:71
virtual FEATURESPLUGIN_EXPORT const std::string & getKind()
Definition: FeaturesPlugin_Rotation.h:106
static const std::string & ANGLE_ID()
Attribute name of angle.
Definition: FeaturesPlugin_Rotation.h:78
Definition: FeaturesPlugin_Rotation.h:43
static const std::string & CENTER_POINT_ID()
Definition: FeaturesPlugin_Rotation.h:85
Rotation kind.
Definition: FeaturesPlugin_Rotation.h:36
Keep the transformation matrix coefficients.
Definition: GeomAPI_Trsf.h:36
