Feature for fusion of connected faces. More...
#include <FeaturesPlugin_FusionFaces.h>
| FeaturesPlugin_FusionFaces () | |
| virtual void | execute () |
| Executes the faces fusion and stores the modififed shape. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_SHAPE_ID () |
| Attribute name of base shape. More... | |
| FeaturesPlugin_FusionFaces::FeaturesPlugin_FusionFaces | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
