Feature for creation of compound from different kinds of shapes. More...
#include <BuildPlugin_Compound.h>
| BuildPlugin_Compound () | |
| virtual void | execute () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| BuildPlugin_Compound::BuildPlugin_Compound | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
