FeaturesPlugin_Pipe Class Reference
Feature for creation of extrusion along a path. More...
#include <FeaturesPlugin_Pipe.h>
Inheritance diagram for FeaturesPlugin_Pipe:
virtual void execute ()
 FeaturesPlugin_Pipe ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_SIMPLE ()
static const std::string & CREATION_METHOD_BINORMAL ()
static const std::string & CREATION_METHOD_LOCATIONS ()
static const std::string & BASE_OBJECTS_ID ()
 Attribute name of base objects. More...
static const std::string & PATH_OBJECT_ID ()
 Attribute name of path object. More...
static const std::string & BINORMAL_ID ()
 Attribute name of Bi-Normal. More...
static const std::string & LOCATIONS_ID ()
 Attribute name of locations. More...
static std::string group ()
Pipe creates extrusion of objects along a path. It produces the following results from objects:
Vertex -> Edge
Edge -> Face
Wire -> Shell
Face -> Solid
◆ FeaturesPlugin_Pipe()
FeaturesPlugin_Pipe::FeaturesPlugin_Pipe ( )
◆ ID()
static const std::string & FeaturesPlugin_Pipe::ID ( )
inlinestatic
Feature kind.
◆ CREATION_METHOD()
static const std::string & FeaturesPlugin_Pipe::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_SIMPLE()
static const std::string & FeaturesPlugin_Pipe::CREATION_METHOD_SIMPLE ( )
inlinestatic
◆ CREATION_METHOD_BINORMAL()
static const std::string & FeaturesPlugin_Pipe::CREATION_METHOD_BINORMAL ( )
inlinestatic
◆ CREATION_METHOD_LOCATIONS()
static const std::string & FeaturesPlugin_Pipe::CREATION_METHOD_LOCATIONS ( )
inlinestatic
◆ BASE_OBJECTS_ID()
static const std::string & FeaturesPlugin_Pipe::BASE_OBJECTS_ID ( )
inlinestatic
◆ PATH_OBJECT_ID()
static const std::string & FeaturesPlugin_Pipe::PATH_OBJECT_ID ( )
inlinestatic
◆ BINORMAL_ID()
static const std::string & FeaturesPlugin_Pipe::BINORMAL_ID ( )
inlinestatic
◆ LOCATIONS_ID()
static const std::string & FeaturesPlugin_Pipe::LOCATIONS_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_Pipe::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_Pipe::execute ( )
◆ initAttributes()
void FeaturesPlugin_Pipe::initAttributes ( )
Implements ModelAPI_Object.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
