FeaturesPlugin_Copy Class Reference
This feature copies the selected results and sub-results (for the whole feature selected all results of this feature are copied). More...
#include <FeaturesPlugin_Copy.h>
Inheritance diagram for FeaturesPlugin_Copy:
virtual void execute ()
virtual void getCopies (ObjectPtr theContext, std::shared_ptr< GeomAPI_Shape > theValue, std::list< ObjectPtr > &theCopyContext, std::list< std::shared_ptr< GeomAPI_Shape > > &theCopyVals)
 To update the group feature which is moved over this copy feature (to add copies to selection) More...
 FeaturesPlugin_Copy ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & OBJECTS ()
 Selection list attribute that contains all copied shapes selection. More...
static const std::string NUMBER ()
 Integer attribute that contains the number of resulting copies needed. More...
static std::string group ()
The referenced arguments of this feature are not concealed. The difference with ”Recover” feature is that not concealed results may be selected and in the history behavior: the “Move to the End” of groups will move to all copy-results.
◆ FeaturesPlugin_Copy()
FeaturesPlugin_Copy::FeaturesPlugin_Copy ( )
◆ ID()
static const std::string & FeaturesPlugin_Copy::ID ( )
inlinestatic
Feature kind.
◆ getKind()
virtual const std::string & FeaturesPlugin_Copy::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ OBJECTS()
static const std::string & FeaturesPlugin_Copy::OBJECTS ( )
inlinestatic
◆ NUMBER()
static const std::string FeaturesPlugin_Copy::NUMBER ( )
inlinestatic
◆ execute()
void FeaturesPlugin_Copy::execute ( )
◆ initAttributes()
void FeaturesPlugin_Copy::initAttributes ( )
Implements ModelAPI_Object.
◆ getCopies()
void FeaturesPlugin_Copy::getCopies ( ObjectPtr  theContext,
std::list< ObjectPtr > &  theCopyContext,
std::list< std::shared_ptr< GeomAPI_Shape > > &  theCopyVals
Implements ModelAPI_FeatureCopyInterface.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
