Feature for applying of placement operation: relative movement of Solid. More...
#include <FeaturesPlugin_Placement.h>
| virtual void | execute () |
| FeaturesPlugin_Placement () | |
| std::wstring | name () |
| Placement kind. More... | |
| static const std::string & | OBJECTS_LIST_ID () |
| attribute name of references sketch entities list, it should contain a sketch result or a pair a sketch result to sketch face More... | |
| static const std::string & | START_SHAPE_ID () |
| attribute name of referenced object More... | |
| static const std::string & | END_SHAPE_ID () |
| attribute name of attractable face More... | |
| static const std::string & | REVERSE_ID () |
| attribute name of flag of reverse direction More... | |
| static const std::string & | CENTERING_ID () |
| attribute name of flag of centering position More... | |
Locates the selected placement_attractable_object (face, edge, vertex) of the solid into the selected placement_base_object. Faces must be planar, edges must be linear. Orientation of the placed solid depends on the underlied planes of both faces.
| FeaturesPlugin_Placement::FeaturesPlugin_Placement | ( | ) |
inlinestatic |
Placement kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
