PrimitivesPlugin_Sphere Class Reference
Feature for creation of a sphere primitive using various methods. More...
#include <PrimitivesPlugin_Sphere.h>
Inheritance diagram for PrimitivesPlugin_Sphere:
virtual PRIMITIVESPLUGIN_EXPORT const std::string & getKind ()
virtual PRIMITIVESPLUGIN_EXPORT void execute ()
virtual PRIMITIVESPLUGIN_EXPORT void initAttributes ()
 PrimitivesPlugin_Sphere ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Sphere kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_BY_PT_RADIUS ()
static const std::string & CREATION_METHOD_BY_DIMENSIONS ()
static const std::string & CENTER_POINT_ID ()
 Attribute name of the base point. More...
static const std::string & RADIUS_ID ()
 Attribute name of the radius. More...
static const std::string & RMIN_ID ()
 attribute name of the inner radius More...
static const std::string & RMAX_ID ()
 attribute name of the outer radius More...
static const std::string & PHIMIN_ID ()
 attribute name of the lower phi limit More...
static const std::string & PHIMAX_ID ()
 attribute name of the higher phi limit More...
static const std::string & THETAMIN_ID ()
 attribute name of the lower theta limit More...
static const std::string & THETAMAX_ID ()
 attribute name of the higher theta limit More...
static std::string group ()
It can be built via two methods : using a radius and a center point defaulting to the origin, or radii (inner and outer) and angle limits (theta and phi).
◆ PrimitivesPlugin_Sphere()
PrimitivesPlugin_Sphere::PrimitivesPlugin_Sphere ( )
◆ ID()
static const std::string & PrimitivesPlugin_Sphere::ID ( )
inlinestatic
Sphere kind.
◆ CREATION_METHOD()
static const std::string & PrimitivesPlugin_Sphere::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_BY_PT_RADIUS()
static const std::string & PrimitivesPlugin_Sphere::CREATION_METHOD_BY_PT_RADIUS ( )
inlinestatic
◆ CREATION_METHOD_BY_DIMENSIONS()
static const std::string & PrimitivesPlugin_Sphere::CREATION_METHOD_BY_DIMENSIONS ( )
inlinestatic
◆ CENTER_POINT_ID()
static const std::string & PrimitivesPlugin_Sphere::CENTER_POINT_ID ( )
inlinestatic
◆ RADIUS_ID()
static const std::string & PrimitivesPlugin_Sphere::RADIUS_ID ( )
inlinestatic
◆ RMIN_ID()
static const std::string & PrimitivesPlugin_Sphere::RMIN_ID ( )
inlinestatic
◆ RMAX_ID()
static const std::string & PrimitivesPlugin_Sphere::RMAX_ID ( )
inlinestatic
◆ PHIMIN_ID()
static const std::string & PrimitivesPlugin_Sphere::PHIMIN_ID ( )
inlinestatic
◆ PHIMAX_ID()
static const std::string & PrimitivesPlugin_Sphere::PHIMAX_ID ( )
inlinestatic
◆ THETAMIN_ID()
static const std::string & PrimitivesPlugin_Sphere::THETAMIN_ID ( )
inlinestatic
◆ THETAMAX_ID()
static const std::string & PrimitivesPlugin_Sphere::THETAMAX_ID ( )
inlinestatic
◆ getKind()
virtual PRIMITIVESPLUGIN_EXPORT const std::string & PrimitivesPlugin_Sphere::getKind ( )
Implements ModelAPI_Feature.
◆ execute()
void PrimitivesPlugin_Sphere::execute ( )
◆ initAttributes()
void PrimitivesPlugin_Sphere::initAttributes ( )
Implements ModelAPI_Object.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
