FeaturesPlugin_BooleanCommon Class Reference
Feature for applying of Boolean Common operation. More...
#include <FeaturesPlugin_BooleanCommon.h>
Inheritance diagram for FeaturesPlugin_BooleanCommon:
enum  OperationType {
  BOOL_CUT , BOOL_FUSE , BOOL_COMMON , BOOL_FILL ,
  BOOL_SMASH
virtual void execute ()
 FeaturesPlugin_BooleanCommon ()
OperationType operationType ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_SIMPLE ()
static const std::string & CREATION_METHOD_ADVANCED ()
static const std::string & OBJECT_LIST_ID ()
 Attribute name of main objects. More...
static const std::string & TOOL_LIST_ID ()
 Attribute name of tool objects. More...
static const std::string & USE_FUZZY_ID ()
 Attribute name of use fuzzy parameter. More...
static const std::string & FUZZY_PARAM_ID ()
 Attribute name of fuzzy parameter. More...
static std::string group ()
void loadNamingDS (std::shared_ptr< ModelAPI_ResultBody > theResultBody, const std::shared_ptr< GeomAPI_Shape > theBaseShape, const ListOfShape &theTools, const std::shared_ptr< GeomAPI_Shape > theResultShape, const GeomMakeShapePtr &theMakeShape)
 Load Naming data structure of the feature to the document. More...
void storeResult (const ListOfShape &theObjects, const ListOfShape &theTools, const GeomShapePtr theResultShape, int &theResultIndex, std::shared_ptr< GeomAlgoAPI_MakeShapeList > theMakeShapeList, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList)
 Store result shape if it is not empty and increase results counter. More...
void initVersion (const std::string &theVersion, const std::shared_ptr< ModelAPI_Attribute > theObjectsAttr=std::shared_ptr< ModelAPI_Attribute >(), const std::shared_ptr< ModelAPI_Attribute > theToolsAttr=std::shared_ptr< ModelAPI_Attribute >())
 Initialize version field of the Boolean feature. More...
bool processAttribute (const std::string &theAttributeName, GeomAPI_ShapeHierarchy &theObjects, ListOfShape &thePlanesList)
 Process SelectionList attribute and fill the objects hierarchy. More...
bool processObject (const GeomAlgoAPI_Tools::BOPType theBooleanType, const GeomShapePtr &theObject, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr())
 Perform Boolean operation of the object with the tools. More...
bool processCompsolid (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompsolidHierarchy, const GeomShapePtr &theCompsolid, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr())
 Perform Boolean operation of the Compsolid with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More...
bool processCompound (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompoundHierarchy, const GeomShapePtr &theCompound, const ListOfShape &theTools, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr())
 Perform Boolean operation of the Compound with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More...
GeomShapePtr keepUnusedSubsOfCompound (const GeomShapePtr &theResult, const GeomAPI_ShapeHierarchy &theObjectsHierarchy, const GeomAPI_ShapeHierarchy &theToolsHierarchy, std::shared_ptr< GeomAlgoAPI_MakeShapeList > theMakeShapeList)
 Process unused sub-shapes of compounds. More...
static const std::string & BOP_VERSION_9_4 ()
static void resizePlanes (const ListOfShape &theObjects, ListOfShape &thePlanes, std::shared_ptr< GeomAlgoAPI_MakeShapeList > &theMakeShapeList)
 Resize planes to fit them to the bounding box of the given lins of objects. More...
◆ FeaturesPlugin_BooleanCommon()
FeaturesPlugin_BooleanCommon::FeaturesPlugin_BooleanCommon ( )
◆ ID()
static const std::string & FeaturesPlugin_BooleanCommon::ID ( )
inlinestatic
Feature kind.
◆ getKind()
virtual const std::string & FeaturesPlugin_BooleanCommon::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ CREATION_METHOD()
static const std::string & FeaturesPlugin_BooleanCommon::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_SIMPLE()
static const std::string & FeaturesPlugin_BooleanCommon::CREATION_METHOD_SIMPLE ( )
inlinestatic
◆ CREATION_METHOD_ADVANCED()
static const std::string & FeaturesPlugin_BooleanCommon::CREATION_METHOD_ADVANCED ( )
inlinestatic
◆ initAttributes()
void FeaturesPlugin_BooleanCommon::initAttributes ( )
Reimplemented from FeaturesPlugin_Boolean.
◆ execute()
void FeaturesPlugin_BooleanCommon::execute ( )
◆ OBJECT_LIST_ID()
static const std::string & FeaturesPlugin_Boolean::OBJECT_LIST_ID ( )
inlinestaticinherited
◆ TOOL_LIST_ID()
static const std::string & FeaturesPlugin_Boolean::TOOL_LIST_ID ( )
◆ USE_FUZZY_ID()
static const std::string & FeaturesPlugin_Boolean::USE_FUZZY_ID ( )
◆ FUZZY_PARAM_ID()
static const std::string & FeaturesPlugin_Boolean::FUZZY_PARAM_ID ( )
◆ operationType()
FeaturesPlugin_Boolean::OperationType FeaturesPlugin_Boolean::operationType ( )
boolean operation type.
◆ loadNamingDS()
void FeaturesPlugin_Boolean::loadNamingDS ( std::shared_ptr< ModelAPI_ResultBody >  theResultBody,
const ListOfShape &  theTools,
const GeomMakeShapePtr &  theMakeShape
◆ storeResult()
void FeaturesPlugin_Boolean::storeResult ( const ListOfShape &  theObjects,
int &  theResultIndex,
std::vector< ModelAPI_Tools::ResultBaseAlgo > &  theResultBaseAlgoList
◆ initVersion()
void FeaturesPlugin_VersionedBoolean::initVersion ( const std::string &  theVersion,
const std::shared_ptr< ModelAPI_Attribute >  theObjectsAttr = std::shared_ptr<ModelAPI_Attribute>(),
const std::shared_ptr< ModelAPI_Attribute >  theToolsAttr = std::shared_ptr<ModelAPI_Attribute>()
The version is initialized for newly created features, not read from previously stored document.
◆ processAttribute()
bool FeaturesPlugin_VersionedBoolean::processAttribute ( const std::string &  theAttributeName,
GeomAPI_ShapeHierarchy &  theObjects,
ListOfShape &  thePlanesList
◆ processObject()
bool FeaturesPlugin_VersionedBoolean::processObject ( const GeomAlgoAPI_Tools::BOPType  theBooleanType,
const GeomShapePtr &  theObject,
const ListOfShape &  thePlanes,
std::vector< ModelAPI_Tools::ResultBaseAlgo > &  theResultBaseAlgoList,
ListOfShape &  theResultShapesList,
GeomShapePtr  theResulCompound = GeomShapePtr()
false if something went wrong
◆ processCompsolid()
bool FeaturesPlugin_VersionedBoolean::processCompsolid ( const GeomAlgoAPI_Tools::BOPType  theBooleanType,
GeomAPI_ShapeHierarchy &  theCompsolidHierarchy,
const GeomShapePtr &  theCompsolid,
◆ processCompound()
bool FeaturesPlugin_VersionedBoolean::processCompound ( const GeomAlgoAPI_Tools::BOPType  theBooleanType,
GeomAPI_ShapeHierarchy &  theCompoundHierarchy,
const GeomShapePtr &  theCompound,
◆ resizePlanes()
void FeaturesPlugin_VersionedBoolean::resizePlanes ( const ListOfShape &  theObjects,
std::shared_ptr< GeomAlgoAPI_MakeShapeList > &  theMakeShapeList
staticprotectedinherited
◆ keepUnusedSubsOfCompound()
GeomShapePtr FeaturesPlugin_VersionedBoolean::keepUnusedSubsOfCompound ( const GeomShapePtr &  theResult,
const GeomAPI_ShapeHierarchy &  theObjectsHierarchy,
const GeomAPI_ShapeHierarchy &  theToolsHierarchy,
Keep the compound hierarchy, but merge top-level compounds into a single compound and add the result of the FUSE operation.
◆ group()
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
Implements ModelAPI_Object.
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
