Feature for changing the scale of an object. More...
#include <FeaturesPlugin_Scale.h>
| virtual FEATURESPLUGIN_EXPORT const std::string & | getKind () |
| virtual FEATURESPLUGIN_EXPORT void | execute () |
| virtual FEATURESPLUGIN_EXPORT void | initAttributes () |
| FeaturesPlugin_Scale () | |
| std::wstring | name () |
| Scale kind. More... | |
| static const std::string & | CREATION_METHOD () |
| Attribute name for creation method. More... | |
| static const std::string & | CREATION_METHOD_BY_FACTOR () |
| Attribute name for creation method "ByFactor". More... | |
| static const std::string & | CREATION_METHOD_BY_DIMENSIONS () |
| static const std::string & | OBJECTS_LIST_ID () |
| Attribute name of referenced objects. More... | |
| static const std::string & | CENTER_POINT_ID () |
| Attribute name of center point. More... | |
| static const std::string & | SCALE_FACTOR_ID () |
| Attribute name of scale factor. More... | |
| static const std::string & | SCALE_FACTOR_X_ID () |
| Attribute name of scale factor in X. More... | |
| static const std::string & | SCALE_FACTOR_Y_ID () |
| Attribute name of scale factor in Y. More... | |
| static const std::string & | SCALE_FACTOR_Z_ID () |
| Attribute name of scale factor in Z. More... | |
| FeaturesPlugin_Scale::FeaturesPlugin_Scale | ( | ) |
inlinestatic |
Scale kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
