Feature for applying the Fillet operations on Solids. More...
#include <FeaturesPlugin_Fillet.h>
| FeaturesPlugin_Fillet () | |
| virtual void | execute () |
| Performs the fillet algorithm and stores it in the data structure. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | CREATION_METHOD () |
| static const std::string | CREATION_METHOD_SINGLE_RADIUS () |
| static const std::string | CREATION_METHOD_VARYING_RADIUS () |
| static const std::string & | OBJECT_LIST_ID () |
| Attribute name of main objects. More... | |
| static const std::string & | START_RADIUS_ID () |
| Attribute name of start radius. More... | |
| static const std::string & | END_RADIUS_ID () |
| Attribute name of end radius. More... | |
| static const std::string & | RADIUS_ID () |
| Attribute name of a radius for fillet with fixed radius. More... | |
| void | initVersion (const std::shared_ptr< ModelAPI_Attribute > &theObjectsAttr) |
| Initialize the version for the newly created feature. More... | |
| bool | processAttribute (const std::shared_ptr< ModelAPI_Attribute > &theAttribute, GeomAPI_ShapeHierarchy &theObjects) |
| Process SelectionList attribute and fill the objects hierarchy. More... | |
Supports fixed radius fillet and varying 2-radius fillet.
| FeaturesPlugin_Fillet::FeaturesPlugin_Fillet | ( | ) |
inlinestatic |
Feature kind.
inlinevirtual |
Implements ModelAPI_Feature.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
Implements ModelAPI_Object.
protectedinherited |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
