PrimitivesPlugin_Cone Class Reference
Feature for creation of a cone. More...
#include <PrimitivesPlugin_Cone.h>
Inheritance diagram for PrimitivesPlugin_Cone:
virtual PRIMITIVESPLUGIN_EXPORT const std::string & getKind ()
virtual PRIMITIVESPLUGIN_EXPORT void execute ()
virtual PRIMITIVESPLUGIN_EXPORT void initAttributes ()
 PrimitivesPlugin_Cone ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Cone kind. More...
static const std::string & BASE_POINT_ID ()
 Attribute name of the base point. More...
static const std::string & AXIS_ID ()
 Attribute name of the axis. More...
static const std::string & BASE_RADIUS_ID ()
 Attribute name of the base radius. More...
static const std::string & TOP_RADIUS_ID ()
 Attribute name of the radius. More...
static const std::string & HEIGHT_ID ()
static std::string group ()
Creates a cone from a
◆ PrimitivesPlugin_Cone()
PrimitivesPlugin_Cone::PrimitivesPlugin_Cone ( )
◆ ID()
static const std::string & PrimitivesPlugin_Cone::ID ( )
inlinestatic
Cone kind.
◆ BASE_POINT_ID()
static const std::string & PrimitivesPlugin_Cone::BASE_POINT_ID ( )
inlinestatic
◆ AXIS_ID()
static const std::string & PrimitivesPlugin_Cone::AXIS_ID ( )
inlinestatic
◆ BASE_RADIUS_ID()
static const std::string & PrimitivesPlugin_Cone::BASE_RADIUS_ID ( )
inlinestatic
◆ TOP_RADIUS_ID()
static const std::string & PrimitivesPlugin_Cone::TOP_RADIUS_ID ( )
inlinestatic
◆ HEIGHT_ID()
static const std::string & PrimitivesPlugin_Cone::HEIGHT_ID ( )
inlinestatic
◆ getKind()
virtual PRIMITIVESPLUGIN_EXPORT const std::string & PrimitivesPlugin_Cone::getKind ( )
Implements ModelAPI_Feature.
◆ execute()
void PrimitivesPlugin_Cone::execute ( )
◆ initAttributes()
void PrimitivesPlugin_Cone::initAttributes ( )
Implements ModelAPI_Object.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
