Feature for creation of a box primitive using various methods. More...
#include <PrimitivesPlugin_Box.h>
| virtual PRIMITIVESPLUGIN_EXPORT const std::string & | getKind () |
| virtual PRIMITIVESPLUGIN_EXPORT void | execute () |
| virtual PRIMITIVESPLUGIN_EXPORT void | initAttributes () |
| PrimitivesPlugin_Box () | |
| std::wstring | name () |
| Box kind. More... | |
| static const std::string & | CREATION_METHOD () |
| Attribute name for creation method. More... | |
| static const std::string & | CREATION_METHOD_BY_DIMENSIONS () |
| static const std::string & | CREATION_METHOD_BY_TWO_POINTS () |
| static const std::string & | CREATION_METHOD_BY_ONE_POINT_AND_DIMS () |
| static const std::string & | POINT_FIRST_ID () |
| Attribute name of first point. More... | |
| static const std::string & | POINT_SECOND_ID () |
| Attribute name of second point. More... | |
| static const std::string & | DX_ID () |
| Attribute first coordinate. More... | |
| static const std::string & | DY_ID () |
| Attribute second coordinate. More... | |
| static const std::string & | DZ_ID () |
| Attribute third coordinate. More... | |
| static const std::string & | OX_ID () |
| Attribute name of the first coordinate of the center. More... | |
| static const std::string & | OY_ID () |
| Attribute name of the second coordinate of the center. More... | |
| static const std::string & | OZ_ID () |
| Attribute name of the third coordinate of the center. More... | |
| static const std::string & | HALF_DX_ID () |
| Attribute name of the half-length on X axis. More... | |
| static const std::string & | HALF_DY_ID () |
| Attribute name of the half-length on Y axis. More... | |
| static const std::string & | HALF_DZ_ID () |
| Attribute name of the half-length on Z axis. More... | |
Box creates a cuboid - Parallelepiped with 6 rectangular faces. It can be built via three methods : using two points that define a diagonal, a point that define a center and 3 lengths that define the half-lengths on X, Y and Z-axes, or using 3 lengths that define the rectangular dimensions.
| PrimitivesPlugin_Box::PrimitivesPlugin_Box | ( | ) |
inlinestatic |
Box kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
