Feature for creation of a tube primitive using various methods. More...
#include <PrimitivesPlugin_Tube.h>
| virtual PRIMITIVESPLUGIN_EXPORT const std::string & | getKind () |
| virtual PRIMITIVESPLUGIN_EXPORT void | execute () |
| virtual PRIMITIVESPLUGIN_EXPORT void | initAttributes () |
| PrimitivesPlugin_Tube () | |
| std::wstring | name () |
| Tube kind. More... | |
| static const std::string & | RMIN_ID () |
| Attrinute name of the inner radius. More... | |
| static const std::string & | RMAX_ID () |
| Attrinute name of the outer radius. More... | |
| static const std::string & | HEIGHT_ID () |
| Attrinute name of the height. More... | |
Tube creates a tuboid - Holed cylinder. It can be built via two methods : using an inner radius, an outer radius and a height or radii (inner and outer) and angles.
| PrimitivesPlugin_Tube::PrimitivesPlugin_Tube | ( | ) |
inlinestatic |
Tube kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
