FeaturesPlugin_Chamfer Class Reference
Feature for applying the Chamfer operations on Solids. More...
#include <FeaturesPlugin_Chamfer.h>
Inheritance diagram for FeaturesPlugin_Chamfer:
 FeaturesPlugin_Chamfer ()
virtual void execute ()
 Performs the fillet algorithm and stores it in the data structure. More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & CREATION_METHOD ()
static const std::string CREATION_METHOD_DISTANCE_DISTANCE ()
static const std::string CREATION_METHOD_DISTANCE_ANGLE ()
static const std::string & OBJECT_LIST_ID ()
 Attribute name of main objects. More...
static const std::string & D1_ID ()
 Attribute name of D1. More...
static const std::string & D2_ID ()
 Attribute name of D2. More...
static const std::string & D_ID ()
 Attribute name of D. More...
static const std::string & ANGLE_ID ()
 Attribute name of Angle. More...
static std::string group ()
void initVersion (const std::shared_ptr< ModelAPI_Attribute > &theObjectsAttr)
 Initialize the version for the newly created feature. More...
bool processAttribute (const std::shared_ptr< ModelAPI_Attribute > &theAttribute, GeomAPI_ShapeHierarchy &theObjects)
 Process SelectionList attribute and fill the objects hierarchy. More...
Supports two distances chamfer and distance-angle chamfer.
◆ FeaturesPlugin_Chamfer()
FeaturesPlugin_Chamfer::FeaturesPlugin_Chamfer ( )
◆ ID()
static const std::string & FeaturesPlugin_Chamfer::ID ( )
inlinestatic
Feature kind.
◆ getKind()
virtual const std::string & FeaturesPlugin_Chamfer::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ OBJECT_LIST_ID()
static const std::string & FeaturesPlugin_Chamfer::OBJECT_LIST_ID ( )
inlinestatic
◆ D1_ID()
static const std::string & FeaturesPlugin_Chamfer::D1_ID ( )
inlinestatic
◆ D2_ID()
static const std::string & FeaturesPlugin_Chamfer::D2_ID ( )
inlinestatic
◆ D_ID()
static const std::string & FeaturesPlugin_Chamfer::D_ID ( )
inlinestatic
◆ ANGLE_ID()
static const std::string & FeaturesPlugin_Chamfer::ANGLE_ID ( )
inlinestatic
◆ initAttributes()
void FeaturesPlugin_Chamfer::initAttributes ( )
Implements ModelAPI_Object.
◆ execute()
void FeaturesPlugin_VersionedChFi::execute ( )
◆ initVersion()
void FeaturesPlugin_VersionedChFi::initVersion ( const std::shared_ptr< ModelAPI_Attribute > &  theObjectsAttr)
◆ processAttribute()
bool FeaturesPlugin_VersionedChFi::processAttribute ( const std::shared_ptr< ModelAPI_Attribute > &  theAttribute,
GeomAPI_ShapeHierarchy &  theObjects
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
