Feature for applying of Union operations on Shapes. More...
#include <FeaturesPlugin_Union.h>
| virtual void | execute () |
| FeaturesPlugin_Union () | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| static const std::string & | USE_FUZZY_ID () |
| Attribute name of use fuzzy parameter. More... | |
| static const std::string & | FUZZY_PARAM_ID () |
| Attribute name of fuzzy parameter. More... | |
| void | initVersion (const std::string &theVersion, const std::shared_ptr< ModelAPI_Attribute > theObjectsAttr=std::shared_ptr< ModelAPI_Attribute >(), const std::shared_ptr< ModelAPI_Attribute > theToolsAttr=std::shared_ptr< ModelAPI_Attribute >()) |
| Initialize version field of the Boolean feature. More... | |
| bool | processAttribute (const std::string &theAttributeName, GeomAPI_ShapeHierarchy &theObjects, ListOfShape &thePlanesList) |
| Process SelectionList attribute and fill the objects hierarchy. More... | |
| bool | processObject (const GeomAlgoAPI_Tools::BOPType theBooleanType, const GeomShapePtr &theObject, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr()) |
| Perform Boolean operation of the object with the tools. More... | |
| bool | processCompsolid (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompsolidHierarchy, const GeomShapePtr &theCompsolid, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr()) |
| Perform Boolean operation of the Compsolid with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More... | |
| bool | processCompound (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompoundHierarchy, const GeomShapePtr &theCompound, const ListOfShape &theTools, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr()) |
| Perform Boolean operation of the Compound with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More... | |
| GeomShapePtr | keepUnusedSubsOfCompound (const GeomShapePtr &theResult, const GeomAPI_ShapeHierarchy &theObjectsHierarchy, const GeomAPI_ShapeHierarchy &theToolsHierarchy, std::shared_ptr< GeomAlgoAPI_MakeShapeList > theMakeShapeList) |
| Process unused sub-shapes of compounds. More... | |
Static Protected Member Functions | |
| static const std::string & | BOP_VERSION_9_4 () |
| static void | resizePlanes (const ListOfShape &theObjects, ListOfShape &thePlanes, std::shared_ptr< GeomAlgoAPI_MakeShapeList > &theMakeShapeList) |
| Resize planes to fit them to the bounding box of the given lins of objects. More... | |
Union removes shared shapes from several shapes and combines them into one.
| FeaturesPlugin_Union::FeaturesPlugin_Union | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
protectedinherited |
The version is initialized for newly created features, not read from previously stored document.
false if something went wrong
staticprotectedinherited |
Keep the compound hierarchy, but merge top-level compounds into a single compound and add the result of the FUSE operation.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
