FeaturesPlugin_Union.h
20#ifndef FeaturesPlugin_Union_H_
21#define FeaturesPlugin_Union_H_
23#include "FeaturesPlugin_VersionedBoolean.h"
24
30{
31public:
33 inline static const std::string& ID()
34 {
35 static const std::string MY_ID("Union");
36 return MY_ID;
37 }
38
40 inline static const std::string& BASE_OBJECTS_ID()
41 {
42 static const std::string MY_BASE_OBJECTS_ID("base_objects");
43 return MY_BASE_OBJECTS_ID;
44 }
45
47 inline static const std::string& USE_FUZZY_ID()
48 {
49 static const std::string MY_USE_FUZZY_ID("use_fuzzy");
50 return MY_USE_FUZZY_ID;
51 }
52
54 inline static const std::string& FUZZY_PARAM_ID()
55 {
56 static const std::string MY_FUZZY_PARAM_ID("fuzzy_param");
57 return MY_FUZZY_PARAM_ID;
58 }
59
61 FEATURESPLUGIN_EXPORT virtual const std::string& getKind()
62 {
63 static std::string MY_KIND = FeaturesPlugin_Union::ID();
64 return MY_KIND;
65 }
66
68 FEATURESPLUGIN_EXPORT virtual void execute();
69
71 FEATURESPLUGIN_EXPORT virtual void initAttributes();
72
75};
76
77#endif
Feature for applying of Union operations on Shapes.
Definition: FeaturesPlugin_Union.h:30
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Union.h:47
Definition: FeaturesPlugin_Union.h:40
Definition: FeaturesPlugin_Union.cpp:48
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Union.h:54
Definition: FeaturesPlugin_Union.h:61
FeaturesPlugin_Union()
Definition: FeaturesPlugin_Union.cpp:43
Feature kind.
Definition: FeaturesPlugin_Union.h:33
Definition: FeaturesPlugin_Union.cpp:61
Feature controls a version of Boolean operations.
Definition: FeaturesPlugin_VersionedBoolean.h:40
