Feature for creation of solid from faces or shells. More...
#include <BuildPlugin_Solid.h>
| BuildPlugin_Solid () | |
| virtual void | execute () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| GeomShapePtr | getSingleSubshape (const GeomShapePtr &theCompound) |
| Explode compound to get single shape. More... | |
| void | getOriginalShapesAndContexts (const std::string &theSelectionListID, ListOfShape &theShapes, ListOfShape &theContexts) |
| Obtain list of selected shapes and their contexts. More... | |
| void | storeResult (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgorithm, const ListOfShape &theOriginalShapes, const ListOfShape &theOriginalContexts, const GeomShapePtr &theResultShape, const int theResultIndex=0) |
| Store result of algorithm. More... | |
| BuildPlugin_Solid::BuildPlugin_Solid | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Object.
Reimplemented in BuildPlugin_CompSolid.
Implements ModelAPI_Feature.
protected |
protectedinherited |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
