Feature for creation of the periodic B-spline curve in the sketch. More...
#include <SketchPlugin_BSplinePeriodic.h>
| virtual SKETCHPLUGIN_EXPORT const std::string & | getKind () |
| SketchPlugin_BSplinePeriodic () | |
| virtual SKETCHPLUGIN_EXPORT bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| virtual SKETCHPLUGIN_EXPORT void | attributeChanged (const std::string &theID) |
| virtual SKETCHPLUGIN_EXPORT void | execute () |
| virtual SKETCHPLUGIN_EXPORT bool | customAction (const std::string &theActionId) |
| Updates the B-spline curve. More... | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true of the feature is a copy of other feature. More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| std::wstring | name () |
| B-spline feature kind. More... | |
| static const std::string & | POLES_ID () |
| list of B-spline poles More... | |
| static const std::string & | WEIGHTS_ID () |
| list of B-spline weights More... | |
| static const std::string & | DEGREE_ID () |
| attribute to store the degree of B-spline More... | |
| static const std::string & | KNOTS_ID () |
| list of B-spline knots More... | |
| static const std::string & | MULTS_ID () |
| list of B-spline multiplicities More... | |
| static const std::string & | ADD_POLE_ACTION_ID () |
| name for add pole action More... | |
| static const std::string & | AUXILIARY_ID () |
| Reference to the construction type of the feature. More... | |
| static const std::string & | EXTERNAL_ID () |
| Reference to the external edge or vertex as a AttributeSelection. More... | |
| static const std::string & | COPY_ID () |
| Reference to the copy type of the feature. More... | |
| static const std::string & | PARENT_ID () |
| Reference to the parent feature if exist. More... | |
| static const int | SKETCH_LINE_WIDTH_AUXILIARY () |
| Width of the auxiliary line. More... | |
| static const int | SKETCH_LINE_WIDTH () |
| Width of the line. More... | |
| static const int | SKETCH_LINE_STYLE_AUXILIARY () |
| Style of the auxiliary line. More... | |
| static const int | SKETCH_LINE_STYLE () |
| Style of the line. More... | |
| virtual bool | isPeriodic () const |
Return true if the B-spline curve is periodic. More... | |
| virtual void | initDerivedClassAttributes () |
| Initializes attributes of derived class. More... | |
| bool | addPole (const int theAfter) |
| Add new pole after the pole with the given index. More... | |
| virtual void | initDerivedClassAttributes2 () |
| Initializes attributes of derived class which were added recently. More... | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
| SketchPlugin_BSplinePeriodic::SketchPlugin_BSplinePeriodic | ( | ) |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
inlineprotectedvirtual |
Implements SketchPlugin_BSplineBase.
inlinestaticinherited |
Reimplemented from SketchPlugin_Feature.
Reimplemented in SketchPlugin_BSpline.
| [in] | theActionId | action key id (in following form: Action::Index) |
false in case the action not performed. Reimplemented from ModelAPI_Feature.
protectedvirtualinherited |
Reimplemented from SketchPlugin_SketchEntity.
protectedinherited |
Width of the line.
Style of the line.
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
inlinevirtualinherited |
Reimplemented in SketchPlugin_Projection.
inlineprotectedinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
