SketchPlugin_ConstraintCoincidence Class Reference
Feature for creation of a new constraint which defines equivalence of two points. More...
#include <SketchPlugin_ConstraintCoincidence.h>
Inheritance diagram for SketchPlugin_ConstraintCoincidence:
virtual void execute ()
 SketchPlugin_ConstraintCoincidence ()
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Coincidence constraint kind. More...
static void createCoincidenceFeature (SketchPlugin_Sketch *theSketch, const std::shared_ptr< GeomDataAPI_Point2D > &thePoint1, const std::shared_ptr< GeomDataAPI_Point2D > &thePoint2)
 Creates a constraint on two points. More...
static std::shared_ptr< GeomDataAPI_Point2D > getPoint (const FeaturePtr &theFeature)
 Returns point of coincidence feature. More...
static std::string group ()
void keepCurrentFeature ()
void restoreCurrentFeature ()
This constraint has two attributes: SketchPlugin_Constraint::ENTITY_A() and SketchPlugin_Constraint::ENTITY_B()
◆ SketchPlugin_ConstraintCoincidence()
SketchPlugin_ConstraintCoincidence::SketchPlugin_ConstraintCoincidence ( )
◆ ID()
static const std::string & SketchPlugin_ConstraintCoincidence::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_ConstraintCoincidence::getKind ( )
Implements ModelAPI_Feature.
Reimplemented in SketchPlugin_ConstraintCoincidenceInternal.
◆ getAISObject()
AISObjectPtr SketchPlugin_ConstraintCoincidence::getAISObject ( AISObjectPtr  thePrevious)
◆ execute()
void SketchPlugin_ConstraintCoincidence::execute ( )
◆ initAttributes()
void SketchPlugin_ConstraintCoincidence::initAttributes ( )
Implements ModelAPI_Object.
◆ createCoincidenceFeature()
void SketchPlugin_ConstraintCoincidence::createCoincidenceFeature ( SketchPlugin_Sketch *  theSketch,
const std::shared_ptr< GeomDataAPI_Point2D > &  thePoint1,
const std::shared_ptr< GeomDataAPI_Point2D > &  thePoint2
theSketcha sketch feature
thePoint1the first point
thePoint2the second point
◆ getPoint()
AttributePoint2DPtr SketchPlugin_ConstraintCoincidence::getPoint ( const FeaturePtr &  theFeature)
theFeaturea coincidence feature
point 2d attribute. Coincidence always has at least one point 2d attribute
◆ VALUE()
inlinestaticinherited
◆ FLYOUT_VALUE_PNT()
◆ CONSTRAINT_ACTIVE()
◆ ENTITY_A()
◆ ENTITY_B()
◆ ENTITY_C()
◆ ENTITY_D()
◆ ATTRIBUTE()
◆ isZeroValueAllowed()
inlinevirtualinherited
◆ setNumericValue()
theValuenew set value
◆ getNumericValue()
◆ isInHistory()
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
