GeomDataAPI_Point2D Class Referenceabstract
Attribute that contains 2D point coordinates. More...
#include <GeomDataAPI_Point2D.h>
Inheritance diagram for GeomDataAPI_Point2D:
enum  PointComponent { C_X = 0 , C_Y = 1 }
 Point component (x,y) More...
virtual GEOMDATAAPI_EXPORT void setValue (const double theX, const double theY)=0
 Defines the double value. More...
virtual GEOMDATAAPI_EXPORT void setValue (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)=0
 Defines the point. More...
virtual GEOMDATAAPI_EXPORT double x () const =0
 Returns the X double value. More...
virtual GEOMDATAAPI_EXPORT double y () const =0
 Returns the Y double value. More...
virtual GEOMDATAAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > pnt ()=0
 Returns the 2D point. More...
virtual GEOMDATAAPI_EXPORT void setCalculatedValue (const double theX, const double theY)=0
 Defines the calculated double value. More...
virtual GEOMDATAAPI_EXPORT void setText (const std::wstring &theX, const std::wstring &theY)=0
 Defines the text values. More...
virtual GEOMDATAAPI_EXPORT std::wstring textX ()=0
 Returns the text value for X. More...
virtual GEOMDATAAPI_EXPORT std::wstring textY ()=0
 Returns the text value for Y. More...
virtual GEOMDATAAPI_EXPORT void setExpressionInvalid (int theComponent, const bool theFlag)=0
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual GEOMDATAAPI_EXPORT bool expressionInvalid (int theComponent)=0
 Returns true if text is invalid. More...
virtual GEOMDATAAPI_EXPORT void setExpressionError (int theComponent, const std::string &theError)=0
 Allows to set expression (text) error (by the parameters listener) More...
virtual GEOMDATAAPI_EXPORT std::string expressionError (int theComponent)=0
 Returns an expression error. More...
virtual GEOMDATAAPI_EXPORT void setUsedParameters (int theComponent, const std::set< std::wstring > &theUsedParameters)=0
 Defines the used parameters. More...
virtual GEOMDATAAPI_EXPORT std::set< std::wstring > usedParameters (int theComponent) const =0
 Returns the used parameters. More...
GEOMDATAAPI_EXPORT void move (const double theDeltaX, const double theDeltaY)
 Appends the delta values to point. More...
virtual GEOMDATAAPI_EXPORT std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
static GEOMDATAAPI_EXPORT std::shared_ptr< GeomDataAPI_Point2D > getPoint2D (const DataPtr &theData, const std::string &theAttribute)
 Returns this attribute from the data if it is possible. More...
GEOMDATAAPI_EXPORT GeomDataAPI_Point2D ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ PointComponent
◆ GeomDataAPI_Point2D()
GeomDataAPI_Point2D::GeomDataAPI_Point2D ( )
◆ setValue() [1/2]
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setValue ( const double  theX,
const double  theY
pure virtual
Implemented in GeomData_Point2D.
◆ setValue() [2/2]
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setValue ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint)
pure virtual
Defines the point.
◆ x()
virtual GEOMDATAAPI_EXPORT double GeomDataAPI_Point2D::x ( ) const
pure virtual
◆ y()
virtual GEOMDATAAPI_EXPORT double GeomDataAPI_Point2D::y ( ) const
pure virtual
◆ pnt()
virtual GEOMDATAAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > GeomDataAPI_Point2D::pnt ( )
pure virtual
◆ setCalculatedValue()
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setCalculatedValue ( const double  theX,
const double  theY
pure virtual
◆ setText()
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setText ( const std::wstring &  theX,
const std::wstring &  theY
pure virtual
◆ textX()
virtual GEOMDATAAPI_EXPORT std::wstring GeomDataAPI_Point2D::textX ( )
pure virtual
◆ textY()
virtual GEOMDATAAPI_EXPORT std::wstring GeomDataAPI_Point2D::textY ( )
pure virtual
◆ setExpressionInvalid()
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setExpressionInvalid ( int  theComponent,
const bool  theFlag
pure virtual
◆ expressionInvalid()
virtual GEOMDATAAPI_EXPORT bool GeomDataAPI_Point2D::expressionInvalid ( int  theComponent)
pure virtual
◆ setExpressionError()
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setExpressionError ( int  theComponent,
const std::string &  theError
pure virtual
◆ expressionError()
virtual GEOMDATAAPI_EXPORT std::string GeomDataAPI_Point2D::expressionError ( int  theComponent)
pure virtual
◆ setUsedParameters()
virtual GEOMDATAAPI_EXPORT void GeomDataAPI_Point2D::setUsedParameters ( int  theComponent,
const std::set< std::wstring > &  theUsedParameters
pure virtual
◆ usedParameters()
virtual GEOMDATAAPI_EXPORT std::set< std::wstring > GeomDataAPI_Point2D::usedParameters ( int  theComponent) const
pure virtual
◆ move()
void GeomDataAPI_Point2D::move ( const double  theDeltaX,
◆ typeId()
static std::string GeomDataAPI_Point2D::typeId ( )
inlinestatic
◆ attributeType()
std::string GeomDataAPI_Point2D::attributeType ( )
◆ getPoint2D()
std::shared_ptr< GeomDataAPI_Point2D > GeomDataAPI_Point2D::getPoint2D ( const DataPtr &  theData,
const std::string &  theAttribute
theDataa model data
theAttributean attribute index
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
