FeaturesPlugin_Extrusion Class Reference
Feature for creation of extrusion from the planar face. More...
#include <FeaturesPlugin_Extrusion.h>
Inheritance diagram for FeaturesPlugin_Extrusion:
 FeaturesPlugin_Extrusion ()
virtual void execute ()
virtual std::shared_ptr< ModelAPI_Feature > addFeature (std::string theID)
 Appends a feature to the sketch sub-elements container. More...
virtual int numberOfSubs (bool forTree=false) const
virtual std::shared_ptr< ModelAPI_Feature > subFeature (const int theIndex, bool forTree=false)
virtual int subFeatureId (const int theIndex) const
virtual bool isSub (ObjectPtr theObject) const
virtual void removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature)
 This method to inform that sub-feature is removed and must be removed from the internal data structures of the owner (the remove from the document will be done outside just after). More...
virtual void erase ()
 in addition removes all subs More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_BY_SIZES ()
static const std::string & CREATION_METHOD_BY_PLANES ()
static const std::string & CREATION_METHOD_THROUGH_ALL ()
static const std::string & DIRECTION_OBJECT_ID ()
 Attribute name of an object to which the extrusion grows. More...
static const std::string & TO_SIZE_ID ()
 Attribute name of extrusion to size. More...
static const std::string & FROM_SIZE_ID ()
 Attribute name of extrusion from size. More...
static const std::string & TO_OBJECT_ID ()
static const std::string & TO_OFFSET_ID ()
 Attribute name of extrusion offset. More...
static const std::string & FROM_OBJECT_ID ()
 Attribute name of an object from which the extrusion grows. More...
static const std::string & FROM_OFFSET_ID ()
static const std::string & SKETCH_ID ()
 Attribute name of sketch feature. More...
static const std::string & BASE_OBJECTS_ID ()
 Attribute name of base objects. More...
static std::string group ()
Protected Types
enum  InitFlags { InitSketchLauncher = 1 << 0 , InitBaseObjectsList = 1 << 1 }
bool makeExtrusions (ListOfShape &theBaseShapes, ListOfShape &theBoundaryShapes, ListOfMakeShape &theMakeShapes)
 Generates extrusions. More...
void storeResultWithBoundaries (const GeomShapePtr theBaseShape, const ListOfShape &theBoundaryShapes, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0)
 Stores result of generation. More...
void getDirection (std::shared_ptr< GeomAPI_Dir > &theDir)
 Retrieve direction argument. More...
virtual void getSizes (double &theToSize, double &theFromSize)
 Retrieve or calculate prism sizes. More...
void initCompositeSketchAttribtues (const int theInitFlags)
 Initializes composite sketch attributes. More...
void getBaseShapes (ListOfShape &theBaseShapesList, const bool theIsMakeShells=true)
 Returns list of base shapes. More...
void storeResult (const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0)
void storeGenerationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
 Stores generation history. More...
void storeShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, ResultBodyPtr theResultBody, const GeomAPI_Shape::ShapeType theBaseShapeType, const ListOfShape &theShapes, const std::string theName)
 Used to store from and to shapes: generated, or in common modified tag. More...
Extrusion creates the lateral faces based on edges of the base face and the top and bottom faces equal to the base face or this faces can be projection on the bounding planes if they were set. Direction of extrusion is taken from the face plane or if the bounding faces were set then it will be from the bottom to the top plane.
◆ FeaturesPlugin_Extrusion()
FeaturesPlugin_Extrusion::FeaturesPlugin_Extrusion ( )
◆ ID()
static const std::string & FeaturesPlugin_Extrusion::ID ( )
inlinestatic
Feature kind.
◆ CREATION_METHOD()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_BY_SIZES()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD_BY_SIZES ( )
inlinestatic
◆ CREATION_METHOD_BY_PLANES()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD_BY_PLANES ( )
inlinestatic
◆ CREATION_METHOD_THROUGH_ALL()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD_THROUGH_ALL ( )
inlinestatic
◆ DIRECTION_OBJECT_ID()
static const std::string & FeaturesPlugin_Extrusion::DIRECTION_OBJECT_ID ( )
inlinestatic
◆ TO_SIZE_ID()
static const std::string & FeaturesPlugin_Extrusion::TO_SIZE_ID ( )
inlinestatic
◆ FROM_SIZE_ID()
static const std::string & FeaturesPlugin_Extrusion::FROM_SIZE_ID ( )
inlinestatic
◆ TO_OBJECT_ID()
static const std::string & FeaturesPlugin_Extrusion::TO_OBJECT_ID ( )
inlinestatic
◆ TO_OFFSET_ID()
static const std::string & FeaturesPlugin_Extrusion::TO_OFFSET_ID ( )
inlinestatic
◆ FROM_OBJECT_ID()
static const std::string & FeaturesPlugin_Extrusion::FROM_OBJECT_ID ( )
inlinestatic
◆ FROM_OFFSET_ID()
static const std::string & FeaturesPlugin_Extrusion::FROM_OFFSET_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_Extrusion::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
Reimplemented in FeaturesPlugin_ExtrusionCut, and FeaturesPlugin_ExtrusionFuse.
◆ initAttributes()
void FeaturesPlugin_Extrusion::initAttributes ( )
Implements ModelAPI_Object.
Reimplemented in FeaturesPlugin_ExtrusionBoolean.
◆ execute()
void FeaturesPlugin_Extrusion::execute ( )
◆ makeExtrusions()
bool FeaturesPlugin_Extrusion::makeExtrusions ( ListOfShape &  theBaseShapes,
ListOfShape &  theBoundaryShapes,
ListOfMakeShape &  theMakeShapes
[out]theBaseShapeslist of base shapes.
[out]theBoundaryShapeslist of faces limiting the extrusion
[out]theMakeShapeslist of according algos.
false in case one of algo failed.
◆ storeResultWithBoundaries()
void FeaturesPlugin_Extrusion::storeResultWithBoundaries ( const GeomShapePtr  theBaseShape,
const ListOfShape &  theBoundaryShapes,
const int  theIndex = 0
◆ getDirection()
void FeaturesPlugin_Extrusion::getDirection ( std::shared_ptr< GeomAPI_Dir > &  theDir)
◆ getSizes()
void FeaturesPlugin_Extrusion::getSizes ( double &  theToSize,
double &  theFromSize
◆ SKETCH_ID()
static const std::string & FeaturesPlugin_CompositeSketch::SKETCH_ID ( )
inlinestaticinherited
◆ BASE_OBJECTS_ID()
static const std::string & FeaturesPlugin_CompositeSketch::BASE_OBJECTS_ID ( )
◆ addFeature()
std::shared_ptr< ModelAPI_Feature > FeaturesPlugin_CompositeSketch::addFeature ( std::string  theID)
Implements ModelAPI_CompositeFeature.
◆ numberOfSubs()
int FeaturesPlugin_CompositeSketch::numberOfSubs ( bool  forTree = false) const
the number of sub-elements.
◆ subFeature()
std::shared_ptr< ModelAPI_Feature > FeaturesPlugin_CompositeSketch::subFeature ( const int  theIndex,
the sub-feature by zero-base index.
◆ subFeatureId()
int FeaturesPlugin_CompositeSketch::subFeatureId ( const int  theIndex) const
the sub-feature unique identifier in this composite feature by zero-base index.
◆ isSub()
bool FeaturesPlugin_CompositeSketch::isSub ( ObjectPtr  theObject) const
true if feature or result belong to this composite feature as subs.
◆ removeFeature()
void FeaturesPlugin_CompositeSketch::removeFeature ( std::shared_ptr< ModelAPI_Feature >  theFeature)
◆ initCompositeSketchAttribtues()
void FeaturesPlugin_CompositeSketch::initCompositeSketchAttribtues ( const int  theInitFlags)
◆ getBaseShapes()
void FeaturesPlugin_CompositeSketch::getBaseShapes ( ListOfShape &  theBaseShapesList,
const bool  theIsMakeShells = true
[out]theBaseShapesListlist of base shapes (warning: list not cleared).
[in]theIsMakeShellsif true make shells from faces with shared edges.
◆ storeResult()
void FeaturesPlugin_CompositeSketch::storeResult ( const GeomShapePtr  theBaseShape,
◆ storeGenerationHistory()
void FeaturesPlugin_CompositeSketch::storeGenerationHistory ( ResultBodyPtr  theResultBody,
◆ storeShapes()
void FeaturesPlugin_CompositeSketch::storeShapes ( const std::shared_ptr< GeomAlgoAPI_MakeShape >  theMakeShape,
const ListOfShape &  theShapes,
◆ erase()
void ModelAPI_CompositeFeature::erase ( )
◆ group()
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
