Interface for the composite extrusion feature. More...
#include <FeaturesPlugin_ExtrusionBoolean.h>
Public Types | |
| enum | OperationType { BOOL_CUT , BOOL_FUSE , BOOL_COMMON , BOOL_SMASH } |
| virtual void | execute () |
| virtual std::shared_ptr< ModelAPI_Feature > | addFeature (std::string theID) |
| Appends a feature to the sketch sub-elements container. More... | |
| virtual int | numberOfSubs (bool forTree=false) const |
| virtual std::shared_ptr< ModelAPI_Feature > | subFeature (const int theIndex, bool forTree=false) |
| virtual int | subFeatureId (const int theIndex) const |
| virtual bool | isSub (ObjectPtr theObject) const |
| virtual void | removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature) |
| This method to inform that sub-feature is removed and must be removed from the internal data structures of the owner (the remove from the document will be done outside just after). More... | |
| virtual void | erase () |
| in addition removes all subs More... | |
| std::wstring | name () |
| virtual void | executeCompositeBoolean () |
| const OperationType & | operationType () const |
| Feature kind. More... | |
| static const std::string & | CREATION_METHOD () |
| Attribute name for creation method. More... | |
| static const std::string & | CREATION_METHOD_BY_SIZES () |
| static const std::string & | CREATION_METHOD_BY_PLANES () |
| static const std::string & | CREATION_METHOD_THROUGH_ALL () |
| static const std::string & | DIRECTION_OBJECT_ID () |
| Attribute name of an object to which the extrusion grows. More... | |
| static const std::string & | TO_SIZE_ID () |
| Attribute name of extrusion to size. More... | |
| static const std::string & | FROM_SIZE_ID () |
| Attribute name of extrusion from size. More... | |
| static const std::string & | TO_OBJECT_ID () |
| static const std::string & | TO_OFFSET_ID () |
| Attribute name of extrusion offset. More... | |
| static const std::string & | FROM_OBJECT_ID () |
| Attribute name of an object from which the extrusion grows. More... | |
| static const std::string & | FROM_OFFSET_ID () |
| static const std::string & | SKETCH_ID () |
| Attribute name of sketch feature. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| static const std::string & | OBJECTS_ID () |
| Attribute name of main objects. More... | |
Protected Types | |
| enum | InitFlags { InitSketchLauncher = 1 << 0 , InitBaseObjectsList = 1 << 1 } |
| bool | makeGeneration (ListOfShape &theBaseShapes, ListOfMakeShape &theMakeShapes) |
| This function need to be defined for extrusion/revolution generation. More... | |
| void | storeGenerationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape) |
| Stores generation history. More... | |
| virtual void | getSizes (double &theToSize, double &theFromSize) |
| Calculate prism sizes to ensure that it passes through all objects Redefined from FeaturesPlugin_Extrusion. More... | |
| bool | makeExtrusions (ListOfShape &theBaseShapes, ListOfShape &theBoundaryShapes, ListOfMakeShape &theMakeShapes) |
| Generates extrusions. More... | |
| void | storeResultWithBoundaries (const GeomShapePtr theBaseShape, const ListOfShape &theBoundaryShapes, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0) |
| Stores result of generation. More... | |
| void | getDirection (std::shared_ptr< GeomAPI_Dir > &theDir) |
| Retrieve direction argument. More... | |
| void | initCompositeSketchAttribtues (const int theInitFlags) |
| Initializes composite sketch attributes. More... | |
| void | getBaseShapes (ListOfShape &theBaseShapesList, const bool theIsMakeShells=true) |
| Returns list of base shapes. More... | |
| void | storeResult (const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0) |
| void | storeShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, ResultBodyPtr theResultBody, const GeomAPI_Shape::ShapeType theBaseShapeType, const ListOfShape &theShapes, const std::string theName) |
| Used to store from and to shapes: generated, or in common modified tag. More... | |
| void | initBooleanAttributes () |
| Initializes boolean attributes. More... | |
| bool | makeBoolean (const ListOfShape &theTools, ListOfShape &theObjects, ListOfMakeShape &theMakeShapes) |
| Makes boolean operation. More... | |
| void | storeModificationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theObject, const ListOfShape &theTools, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape) |
| Stores modification history. More... | |
| void | storeDeletedShapes (std::vector< ResultBaseAlgo > &theResultBaseAlgoList, const ListOfShape &theTools, const GeomShapePtr theResultShapesCompound) |
| Stores deleted shapes. More... | |
Protected Attributes | |
| ModelAPI_Feature * | myFeature |
| OperationType | myOperationType |
Reimplemented from FeaturesPlugin_Extrusion.
protectedvirtual |
Implements FeaturesPlugin_CompositeBoolean.
protectedvirtual |
protectedvirtual |
inlinestaticinherited |
Feature kind.
inlinevirtualinherited |
Implements ModelAPI_Feature.
Reimplemented in FeaturesPlugin_ExtrusionCut, and FeaturesPlugin_ExtrusionFuse.
protectedinherited |
| [out] | theBaseShapes | list of base shapes. |
| [out] | theBoundaryShapes | list of faces limiting the extrusion |
| [out] | theMakeShapes | list of according algos. |
Implements ModelAPI_CompositeFeature.
| [out] | theBaseShapesList | list of base shapes (warning: list not cleared). |
| [in] | theIsMakeShells | if true make shells from faces with shared edges. |
inlineinherited |
Implements ModelAPI_Object.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
| [in] | theTools | list of tools. |
| [out] | theObjects | list of objects. |
