Interface for the composite sketch feature. More...
#include <FeaturesPlugin_CompositeSketch.h>
| virtual std::shared_ptr< ModelAPI_Feature > | addFeature (std::string theID) |
| Appends a feature to the sketch sub-elements container. More... | |
| virtual int | numberOfSubs (bool forTree=false) const |
| virtual std::shared_ptr< ModelAPI_Feature > | subFeature (const int theIndex, bool forTree=false) |
| virtual int | subFeatureId (const int theIndex) const |
| virtual bool | isSub (ObjectPtr theObject) const |
| virtual void | removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature) |
| This method to inform that sub-feature is removed and must be removed from the internal data structures of the owner (the remove from the document will be done outside just after). More... | |
| virtual void | erase () |
| in addition removes all subs More... | |
| virtual const std::string & | getKind ()=0 |
| Returns the unique kind of a feature (like "Point") More... | |
| virtual void | execute ()=0 |
| std::wstring | name () |
| virtual void | initAttributes ()=0 |
| Request for initialization of data model of the object: adding all attributes. More... | |
| static const std::string & | SKETCH_ID () |
| Attribute name of sketch feature. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
Protected Types | |
| enum | InitFlags { InitSketchLauncher = 1 << 0 , InitBaseObjectsList = 1 << 1 } |
| void | initCompositeSketchAttribtues (const int theInitFlags) |
| Initializes composite sketch attributes. More... | |
| void | getBaseShapes (ListOfShape &theBaseShapesList, const bool theIsMakeShells=true) |
| Returns list of base shapes. More... | |
| void | storeResult (const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0) |
| Stores result of generation. More... | |
| void | storeGenerationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape) |
| Stores generation history. More... | |
| void | storeShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, ResultBodyPtr theResultBody, const GeomAPI_Shape::ShapeType theBaseShapeType, const ListOfShape &theShapes, const std::string theName) |
| Used to store from and to shapes: generated, or in common modified tag. More... | |
inlinestatic |
inlinestatic |
Implements ModelAPI_CompositeFeature.
protected |
protected |
| [out] | theBaseShapesList | list of base shapes (warning: list not cleared). |
| [in] | theIsMakeShells | if true make shells from faces with shared edges. |
protected |
protected |
protected |
pure virtualinherited |
Implemented in BuildPlugin_Compound, BuildPlugin_CompSolid, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupAddition, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupShape, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportPart, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_Chamfer, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionCut, FeaturesPlugin_ExtrusionFuse, FeaturesPlugin_Fillet, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionCut, FeaturesPlugin_RevolutionFuse, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, FiltersPlugin_Selection, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_Arc, SketchPlugin_BSpline, SketchPlugin_BSplinePeriodic, SketchPlugin_Circle, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceHorizontal, SketchPlugin_ConstraintDistanceVertical, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_CurveFitting, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_Fillet, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroBSplinePeriodic, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Point, SketchPlugin_Projection, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_Split, SketchPlugin_Trim, ExchangePlugin_Import, ExchangePlugin_Import_Image, ExchangePlugin_ImportFeature, ExchangePlugin_Import_ImageFeature, and ExchangePlugin_ImportFeatureBase.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
Implements ModelAPI_Object.
Implemented in BuildPlugin_Compound, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupAddition, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupShape, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportPart, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_BoundingBoxBase, FeaturesPlugin_CommonSharedFaces, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionCut, FeaturesPlugin_ExtrusionFuse, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionCut, FeaturesPlugin_RevolutionFuse, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, FeaturesPlugin_VersionedChFi, FiltersPlugin_Selection, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceAlongDir, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_CurveFitting, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_Fillet, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Point, SketchPlugin_Projection, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_Split, SketchPlugin_Trim, ExchangePlugin_Import, ExchangePlugin_Import_Image, ExchangePlugin_ImportFeature, ExchangePlugin_Import_ImageFeature, ExchangePlugin_ImportBase, and ExchangePlugin_ImportFeatureBase.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
Implemented in BuildPlugin_Compound, BuildPlugin_CompSolid, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupMerge, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportBase, ExchangePlugin_Import, ExchangePlugin_ImportFeatureBase, ExchangePlugin_ImportFeature, ExchangePlugin_ImportPart, FeaturesPlugin_Boolean, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_Chamfer, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionBoolean, FeaturesPlugin_Fillet, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionBoolean, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, Model_ResultBody, Model_ResultParameter, Model_ResultPart, ModelAPI_Folder, ModelAPI_Result, ModelAPI_ResultField::ModelAPI_FieldStep, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceAlongDir, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_SketchEntity, SketchPlugin_Split, SketchPlugin_Trim, FiltersPlugin_Selection, and ModelAPI_ResultParameter.
