Folder feature (groups the features). More...
#include <ModelAPI_Folder.h>
| virtual MODELAPI_EXPORT | ~ModelAPI_Folder () |
| To virtually destroy the fields of successors. More... | |
| virtual MODELAPI_EXPORT void | initAttributes () |
| Request for initialization of data model of the object: adding all attributes. More... | |
| virtual MODELAPI_EXPORT void | execute () |
| virtual bool | isDisabled () |
| std::wstring | name () |
| MODELAPI_EXPORT std::shared_ptr< ModelAPI_Feature > | lastVisibleFeature () |
| Returns the last visible feature in the folder, passing through invisible, that may appear as the last ones. More... | |
| Folder feature ID. More... | |
| static const std::string & | FIRST_FEATURE_ID () |
| Attribute referring first feature in the folder. More... | |
| static const std::string & | LAST_FEATURE_ID () |
| Attribute referring last feature in the folder. More... | |
| virtual void | erase () |
| removes all fields from this feature More... | |
inlinestatic |
Folder feature ID.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Object.
inlinestatic |
inlinestatic |
inlinevirtual |
inline |
inline |
| std::shared_ptr< ModelAPI_Feature > ModelAPI_Folder::lastVisibleFeature | ( | ) |
protectedvirtual |
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
inlinevirtualinherited |
protectedvirtualinherited |
Reimplemented in ModelAPI_CompositeFeature, ModelAPI_Feature, PartSetPlugin_Part, SketchPlugin_ConstraintMirror, SketchPlugin_MultiRotation, and SketchPlugin_MultiTranslation.
