Feature for creation of shell from faces and shells. More...
#include <BuildPlugin_Shell.h>
| BuildPlugin_Shell () | |
| virtual void | execute () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| void | getOriginalShapesAndContexts (const std::string &theSelectionListID, ListOfShape &theShapes, ListOfShape &theContexts) |
| Obtain list of selected shapes and their contexts. More... | |
| void | storeResult (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgorithm, const ListOfShape &theOriginalShapes, const ListOfShape &theOriginalContexts, const GeomShapePtr &theResultShape, const int theResultIndex=0) |
| Store result of algorithm. More... | |
| BuildPlugin_Shell::BuildPlugin_Shell | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
protectedinherited |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
