FeaturesPlugin_ExtrusionCut Class Reference
This feature allows to create sketch, extrude faces from this sketch and cut result from other objects in a single operation. More...
#include <FeaturesPlugin_ExtrusionCut.h>
Inheritance diagram for FeaturesPlugin_ExtrusionCut:
enum  OperationType { BOOL_CUT , BOOL_FUSE , BOOL_COMMON , BOOL_SMASH }
 FeaturesPlugin_ExtrusionCut ()
virtual void execute ()
virtual std::shared_ptr< ModelAPI_Feature > addFeature (std::string theID)
 Appends a feature to the sketch sub-elements container. More...
virtual int numberOfSubs (bool forTree=false) const
virtual std::shared_ptr< ModelAPI_Feature > subFeature (const int theIndex, bool forTree=false)
virtual int subFeatureId (const int theIndex) const
virtual bool isSub (ObjectPtr theObject) const
virtual void removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature)
 This method to inform that sub-feature is removed and must be removed from the internal data structures of the owner (the remove from the document will be done outside just after). More...
virtual void erase ()
 in addition removes all subs More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
virtual void executeCompositeBoolean ()
const OperationType & operationType () const
 Feature kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_BY_SIZES ()
static const std::string & CREATION_METHOD_BY_PLANES ()
static const std::string & CREATION_METHOD_THROUGH_ALL ()
static const std::string & DIRECTION_OBJECT_ID ()
 Attribute name of an object to which the extrusion grows. More...
static const std::string & TO_SIZE_ID ()
 Attribute name of extrusion to size. More...
static const std::string & FROM_SIZE_ID ()
 Attribute name of extrusion from size. More...
static const std::string & TO_OBJECT_ID ()
static const std::string & TO_OFFSET_ID ()
 Attribute name of extrusion offset. More...
static const std::string & FROM_OBJECT_ID ()
 Attribute name of an object from which the extrusion grows. More...
static const std::string & FROM_OFFSET_ID ()
static const std::string & SKETCH_ID ()
 Attribute name of sketch feature. More...
static const std::string & BASE_OBJECTS_ID ()
 Attribute name of base objects. More...
static std::string group ()
static const std::string & OBJECTS_ID ()
 Attribute name of main objects. More...
Protected Types
enum  InitFlags { InitSketchLauncher = 1 << 0 , InitBaseObjectsList = 1 << 1 }
bool makeGeneration (ListOfShape &theBaseShapes, ListOfMakeShape &theMakeShapes)
 This function need to be defined for extrusion/revolution generation. More...
void storeGenerationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
 Stores generation history. More...
virtual void getSizes (double &theToSize, double &theFromSize)
 Calculate prism sizes to ensure that it passes through all objects Redefined from FeaturesPlugin_Extrusion. More...
bool makeExtrusions (ListOfShape &theBaseShapes, ListOfShape &theBoundaryShapes, ListOfMakeShape &theMakeShapes)
 Generates extrusions. More...
void storeResultWithBoundaries (const GeomShapePtr theBaseShape, const ListOfShape &theBoundaryShapes, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0)
 Stores result of generation. More...
void getDirection (std::shared_ptr< GeomAPI_Dir > &theDir)
 Retrieve direction argument. More...
void initCompositeSketchAttribtues (const int theInitFlags)
 Initializes composite sketch attributes. More...
void getBaseShapes (ListOfShape &theBaseShapesList, const bool theIsMakeShells=true)
 Returns list of base shapes. More...
void storeResult (const GeomShapePtr theBaseShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const int theIndex=0)
void storeShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, ResultBodyPtr theResultBody, const GeomAPI_Shape::ShapeType theBaseShapeType, const ListOfShape &theShapes, const std::string theName)
 Used to store from and to shapes: generated, or in common modified tag. More...
void initBooleanAttributes ()
 Initializes boolean attributes. More...
bool makeBoolean (const ListOfShape &theTools, ListOfShape &theObjects, ListOfMakeShape &theMakeShapes)
 Makes boolean operation. More...
void storeModificationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theObject, const ListOfShape &theTools, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
 Stores modification history. More...
void storeDeletedShapes (std::vector< ResultBaseAlgo > &theResultBaseAlgoList, const ListOfShape &theTools, const GeomShapePtr theResultShapesCompound)
 Stores deleted shapes. More...
ModelAPI_Feature * myFeature
OperationType myOperationType
◆ FeaturesPlugin_ExtrusionCut()
FeaturesPlugin_ExtrusionCut::FeaturesPlugin_ExtrusionCut ( )
◆ ID()
static const std::string & FeaturesPlugin_ExtrusionCut::ID ( )
inlinestatic
Feature kind.
◆ getKind()
virtual const std::string & FeaturesPlugin_ExtrusionCut::getKind ( )
the kind of a feature
Reimplemented from FeaturesPlugin_Extrusion.
◆ execute()
void FeaturesPlugin_ExtrusionCut::execute ( )
◆ initAttributes()
void FeaturesPlugin_ExtrusionBoolean::initAttributes ( )
◆ makeGeneration()
bool FeaturesPlugin_ExtrusionBoolean::makeGeneration ( ListOfShape &  theBaseShapes,
ListOfMakeShape &  theMakeShapes
Implements FeaturesPlugin_CompositeBoolean.
◆ storeGenerationHistory()
void FeaturesPlugin_ExtrusionBoolean::storeGenerationHistory ( ResultBodyPtr  theResultBody,
◆ getSizes()
void FeaturesPlugin_ExtrusionBoolean::getSizes ( double &  theToSize,
double &  theFromSize
◆ CREATION_METHOD()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD ( )
inlinestaticinherited
◆ CREATION_METHOD_BY_SIZES()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD_BY_SIZES ( )
◆ CREATION_METHOD_BY_PLANES()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD_BY_PLANES ( )
◆ CREATION_METHOD_THROUGH_ALL()
static const std::string & FeaturesPlugin_Extrusion::CREATION_METHOD_THROUGH_ALL ( )
◆ DIRECTION_OBJECT_ID()
static const std::string & FeaturesPlugin_Extrusion::DIRECTION_OBJECT_ID ( )
◆ TO_SIZE_ID()
static const std::string & FeaturesPlugin_Extrusion::TO_SIZE_ID ( )
◆ FROM_SIZE_ID()
static const std::string & FeaturesPlugin_Extrusion::FROM_SIZE_ID ( )
◆ TO_OBJECT_ID()
static const std::string & FeaturesPlugin_Extrusion::TO_OBJECT_ID ( )
◆ TO_OFFSET_ID()
static const std::string & FeaturesPlugin_Extrusion::TO_OFFSET_ID ( )
◆ FROM_OBJECT_ID()
static const std::string & FeaturesPlugin_Extrusion::FROM_OBJECT_ID ( )
◆ FROM_OFFSET_ID()
static const std::string & FeaturesPlugin_Extrusion::FROM_OFFSET_ID ( )
◆ makeExtrusions()
bool FeaturesPlugin_Extrusion::makeExtrusions ( ListOfShape &  theBaseShapes,
ListOfShape &  theBoundaryShapes,
[out]theBaseShapeslist of base shapes.
[out]theBoundaryShapeslist of faces limiting the extrusion
[out]theMakeShapeslist of according algos.
false in case one of algo failed.
◆ storeResultWithBoundaries()
void FeaturesPlugin_Extrusion::storeResultWithBoundaries ( const GeomShapePtr  theBaseShape,
const ListOfShape &  theBoundaryShapes,
const int  theIndex = 0
◆ getDirection()
void FeaturesPlugin_Extrusion::getDirection ( std::shared_ptr< GeomAPI_Dir > &  theDir)
◆ SKETCH_ID()
static const std::string & FeaturesPlugin_CompositeSketch::SKETCH_ID ( )
◆ BASE_OBJECTS_ID()
static const std::string & FeaturesPlugin_CompositeSketch::BASE_OBJECTS_ID ( )
◆ addFeature()
std::shared_ptr< ModelAPI_Feature > FeaturesPlugin_CompositeSketch::addFeature ( std::string  theID)
Implements ModelAPI_CompositeFeature.
◆ numberOfSubs()
int FeaturesPlugin_CompositeSketch::numberOfSubs ( bool  forTree = false) const
the number of sub-elements.
◆ subFeature()
std::shared_ptr< ModelAPI_Feature > FeaturesPlugin_CompositeSketch::subFeature ( const int  theIndex,
the sub-feature by zero-base index.
◆ subFeatureId()
int FeaturesPlugin_CompositeSketch::subFeatureId ( const int  theIndex) const
the sub-feature unique identifier in this composite feature by zero-base index.
◆ isSub()
bool FeaturesPlugin_CompositeSketch::isSub ( ObjectPtr  theObject) const
true if feature or result belong to this composite feature as subs.
◆ removeFeature()
void FeaturesPlugin_CompositeSketch::removeFeature ( std::shared_ptr< ModelAPI_Feature >  theFeature)
◆ initCompositeSketchAttribtues()
void FeaturesPlugin_CompositeSketch::initCompositeSketchAttribtues ( const int  theInitFlags)
◆ getBaseShapes()
void FeaturesPlugin_CompositeSketch::getBaseShapes ( ListOfShape &  theBaseShapesList,
const bool  theIsMakeShells = true
[out]theBaseShapesListlist of base shapes (warning: list not cleared).
[in]theIsMakeShellsif true make shells from faces with shared edges.
◆ storeResult()
void FeaturesPlugin_CompositeSketch::storeResult ( const GeomShapePtr  theBaseShape,
◆ storeShapes()
void FeaturesPlugin_CompositeSketch::storeShapes ( const std::shared_ptr< GeomAlgoAPI_MakeShape >  theMakeShape,
const ListOfShape &  theShapes,
◆ erase()
void ModelAPI_CompositeFeature::erase ( )
◆ group()
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
Implements ModelAPI_Object.
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
◆ OBJECTS_ID()
static const std::string & FeaturesPlugin_CompositeBoolean::OBJECTS_ID ( )
◆ executeCompositeBoolean()
void FeaturesPlugin_CompositeBoolean::executeCompositeBoolean ( )
◆ initBooleanAttributes()
void FeaturesPlugin_CompositeBoolean::initBooleanAttributes ( )
◆ makeBoolean()
bool FeaturesPlugin_CompositeBoolean::makeBoolean ( const ListOfShape &  theTools,
ListOfShape &  theObjects,
[in]theToolslist of tools.
[out]theObjectslist of objects.
false if failed.
◆ storeModificationHistory()
void FeaturesPlugin_CompositeBoolean::storeModificationHistory ( ResultBodyPtr  theResultBody,
◆ storeDeletedShapes()
void FeaturesPlugin_CompositeBoolean::storeDeletedShapes ( std::vector< ResultBaseAlgo > &  theResultBaseAlgoList,
