FeaturesPlugin_CompositeBoolean Class Referenceabstract
Interface for the composite boolean feature. More...
#include <FeaturesPlugin_CompositeBoolean.h>
Inheritance diagram for FeaturesPlugin_CompositeBoolean:
struct  ResultBaseAlgo
enum  OperationType { BOOL_CUT , BOOL_FUSE , BOOL_COMMON , BOOL_SMASH }
virtual void executeCompositeBoolean ()
const OperationType & operationType () const
static const std::string & OBJECTS_ID ()
 Attribute name of main objects. More...
void initBooleanAttributes ()
 Initializes boolean attributes. More...
virtual bool makeGeneration (ListOfShape &theBaseShapes, ListOfMakeShape &theMakeShapes)=0
 This function need to be defined for extrusion/revolution generation. More...
bool makeBoolean (const ListOfShape &theTools, ListOfShape &theObjects, ListOfMakeShape &theMakeShapes)
 Makes boolean operation. More...
virtual void storeGenerationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theBaseShape, const GeomMakeShapePtr theMakeShape)=0
 Stores generation history. More...
void storeModificationHistory (ResultBodyPtr theResultBody, const GeomShapePtr theObject, const ListOfShape &theTools, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
 Stores modification history. More...
void storeDeletedShapes (std::vector< ResultBaseAlgo > &theResultBaseAlgoList, const ListOfShape &theTools, const GeomShapePtr theResultShapesCompound)
 Stores deleted shapes. More...
ModelAPI_Feature * myFeature
OperationType myOperationType
◆ OBJECTS_ID()
static const std::string & FeaturesPlugin_CompositeBoolean::OBJECTS_ID ( )
inlinestatic
◆ executeCompositeBoolean()
void FeaturesPlugin_CompositeBoolean::executeCompositeBoolean ( )
◆ initBooleanAttributes()
void FeaturesPlugin_CompositeBoolean::initBooleanAttributes ( )
◆ makeGeneration()
virtual bool FeaturesPlugin_CompositeBoolean::makeGeneration ( ListOfShape &  theBaseShapes,
ListOfMakeShape &  theMakeShapes
protectedpure virtual
Implemented in FeaturesPlugin_ExtrusionBoolean, and FeaturesPlugin_RevolutionBoolean.
◆ makeBoolean()
bool FeaturesPlugin_CompositeBoolean::makeBoolean ( const ListOfShape &  theTools,
ListOfShape &  theObjects,
[in]theToolslist of tools.
[out]theObjectslist of objects.
[out]theMakeShapeslist of according algos.
false if failed.
◆ storeGenerationHistory()
virtual void FeaturesPlugin_CompositeBoolean::storeGenerationHistory ( ResultBodyPtr  theResultBody,
◆ storeModificationHistory()
void FeaturesPlugin_CompositeBoolean::storeModificationHistory ( ResultBodyPtr  theResultBody,
◆ storeDeletedShapes()
void FeaturesPlugin_CompositeBoolean::storeDeletedShapes ( std::vector< ResultBaseAlgo > &  theResultBaseAlgoList,
