FeaturesPlugin_CompositeBoolean.h
20#ifndef FeaturesPlugin_CompositeBoolean_H_
21#define FeaturesPlugin_CompositeBoolean_H_
23#include "FeaturesPlugin.h"
24
26#include <ModelAPI_ResultBody.h>
27#include <GeomAlgoAPI_MakeShape.h>
28#include <GeomAlgoAPI_MakeShapeList.h>
34{
35public:
36 enum OperationType {
37 BOOL_CUT,
38 BOOL_FUSE,
39 BOOL_COMMON,
40 BOOL_SMASH
41 };
42
44 inline static const std::string& OBJECTS_ID()
45 {
46 static const std::string MY_OBJECTS_ID("main_objects");
47 return MY_OBJECTS_ID;
48 }
49
51 FEATURESPLUGIN_EXPORT virtual void executeCompositeBoolean();
52
53 const OperationType& operationType() const { return myOperationType; }
54
55protected:
57 ResultBodyPtr resultBody;
58 GeomShapePtr baseShape;
59 std::shared_ptr<GeomAlgoAPI_MakeShape> makeShape;
60 };
61
62protected:
64
67
69 virtual bool makeGeneration(ListOfShape& theBaseShapes,
70 ListOfMakeShape& theMakeShapes) = 0;
71
77 bool makeBoolean(const ListOfShape& theTools,
78 ListOfShape& theObjects,
79 ListOfMakeShape& theMakeShapes);
80
82 virtual void storeGenerationHistory(ResultBodyPtr theResultBody,
83 const GeomShapePtr theBaseShape,
84 const GeomMakeShapePtr theMakeShape) = 0;
85
87 void storeModificationHistory(ResultBodyPtr theResultBody,
88 const GeomShapePtr theObject,
89 const ListOfShape& theTools,
90 const std::shared_ptr<GeomAlgoAPI_MakeShape> theMakeShape);
91
93 void storeDeletedShapes(std::vector<ResultBaseAlgo>& theResultBaseAlgoList,
94 const ListOfShape& theTools,
95 const GeomShapePtr theResultShapesCompound);
96
97private:
105 bool cutRecursiveCompound (const GeomShapePtr theCompound,
106 const ListOfShape& theTools,
107 std::shared_ptr<GeomAlgoAPI_MakeShapeList>& theMakeShapeList,
108 GeomShapePtr& theResult);
109
116 void addSubShapes (const GeomShapePtr theCompound,
117 const ListOfShape& theSubShapesToAvoid,
118 ListOfShape& theSubShapesToAdd);
119
120protected:
121 ModelAPI_Feature* myFeature;
122 OperationType myOperationType;
123};
124
125#endif
Interface for the composite boolean feature.
Definition: FeaturesPlugin_CompositeBoolean.h:34
virtual void storeGenerationHistory(ResultBodyPtr theResultBody, const GeomShapePtr theBaseShape, const GeomMakeShapePtr theMakeShape)=0
Stores generation history.
virtual bool makeGeneration(ListOfShape &theBaseShapes, ListOfMakeShape &theMakeShapes)=0
This function need to be defined for extrusion/revolution generation.
static const std::string & OBJECTS_ID()
Attribute name of main objects.
Definition: FeaturesPlugin_CompositeBoolean.h:44
void initBooleanAttributes()
Initializes boolean attributes.
Definition: FeaturesPlugin_CompositeBoolean.cpp:37
Definition: FeaturesPlugin_CompositeBoolean.cpp:43
bool makeBoolean(const ListOfShape &theTools, ListOfShape &theObjects, ListOfMakeShape &theMakeShapes)
Makes boolean operation.
Definition: FeaturesPlugin_CompositeBoolean.cpp:229
void storeDeletedShapes(std::vector< ResultBaseAlgo > &theResultBaseAlgoList, const ListOfShape &theTools, const GeomShapePtr theResultShapesCompound)
Stores deleted shapes.
Definition: FeaturesPlugin_CompositeBoolean.cpp:555
void storeModificationHistory(ResultBodyPtr theResultBody, const GeomShapePtr theObject, const ListOfShape &theTools, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)
Stores modification history.
Definition: FeaturesPlugin_CompositeBoolean.cpp:538
Definition: FeaturesPlugin_CompositeBoolean.h:56
