Merge several groups of different shape type into a single shape. More...
#include <CollectionPlugin_GroupShape.h>
| void | execute () |
| Creates a new group result if needed. More... | |
| CollectionPlugin_GroupShape ()=default | |
| void | execute (ResultGroupPtr &aGroup) |
| Result of groups is created on the fly and don't stored to the document. More... | |
| virtual bool | customAction (const std::string &theActionId) |
| Used for the split action of the group (Move to the end and split) More... | |
| std::wstring | name () |
| Extrusion kind. More... | |
| static const std::string & | LIST_ID () |
| attribute name of selected entities list More... | |
| void | updateGroupType (const std::string &theAttributeName) |
| Updates the type of selection list based on types of selected groups. More... | |
default |
inlinestatic |
Extrusion kind.
inlinevirtual |
Reimplemented from CollectionPlugin_Group.
unique shape, remove compound on type
inlinestaticinherited |
inlinevirtualinherited |
protectedinherited |
inlineinherited |
Implements ModelAPI_Object.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
