FeaturesPlugin_MultiRotation Class Reference
Feature that rotaes object around an axis an number of times. More...
#include <FeaturesPlugin_MultiRotation.h>
Inheritance diagram for FeaturesPlugin_MultiRotation:
virtual FEATURESPLUGIN_EXPORT const std::string & getKind ()
virtual FEATURESPLUGIN_EXPORT void execute ()
virtual FEATURESPLUGIN_EXPORT void initAttributes ()
 FeaturesPlugin_MultiRotation ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Multi-rotation kind. More...
static const std::string & OBJECTS_LIST_ID ()
 Attribute name of referenced objects. More...
static const std::string & AXIS_ANGULAR_ID ()
 Attribute name of the angular direction. More...
static const std::string & USE_ANGULAR_STEP_ID ()
 Attribute name for use angular step. More...
static const std::string & STEP_ANGULAR_ID ()
 Attribute name of step for the angular. More...
static const std::string & NB_COPIES_ANGULAR_ID ()
 Attribute name of number of copies for angular. More...
static const std::string & USE_RADIAL_DIR_ID ()
 Attribute name for use radial dir. More...
static const std::string & STEP_RADIAL_ID ()
 Attribute name of radial step. More...
static const std::string & NB_COPIES_RADIAL_ID ()
 Attribute name of number of copies for radial. More...
static std::string group ()
The 2D version also makes translated copies of the object and performs the rotation on these as well.
◆ FeaturesPlugin_MultiRotation()
FeaturesPlugin_MultiRotation::FeaturesPlugin_MultiRotation ( )
◆ ID()
static const std::string & FeaturesPlugin_MultiRotation::ID ( )
inlinestatic
◆ OBJECTS_LIST_ID()
static const std::string & FeaturesPlugin_MultiRotation::OBJECTS_LIST_ID ( )
inlinestatic
◆ AXIS_ANGULAR_ID()
static const std::string & FeaturesPlugin_MultiRotation::AXIS_ANGULAR_ID ( )
inlinestatic
◆ USE_ANGULAR_STEP_ID()
static const std::string & FeaturesPlugin_MultiRotation::USE_ANGULAR_STEP_ID ( )
inlinestatic
◆ STEP_ANGULAR_ID()
static const std::string & FeaturesPlugin_MultiRotation::STEP_ANGULAR_ID ( )
inlinestatic
◆ NB_COPIES_ANGULAR_ID()
static const std::string & FeaturesPlugin_MultiRotation::NB_COPIES_ANGULAR_ID ( )
inlinestatic
◆ USE_RADIAL_DIR_ID()
static const std::string & FeaturesPlugin_MultiRotation::USE_RADIAL_DIR_ID ( )
inlinestatic
◆ STEP_RADIAL_ID()
static const std::string & FeaturesPlugin_MultiRotation::STEP_RADIAL_ID ( )
inlinestatic
◆ NB_COPIES_RADIAL_ID()
static const std::string & FeaturesPlugin_MultiRotation::NB_COPIES_RADIAL_ID ( )
inlinestatic
◆ getKind()
virtual FEATURESPLUGIN_EXPORT const std::string & FeaturesPlugin_MultiRotation::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_MultiRotation::execute ( )
◆ initAttributes()
void FeaturesPlugin_MultiRotation::initAttributes ( )
Implements ModelAPI_Object.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
