FeaturesPlugin_MultiRotation.h
20// File: FeaturesPlugin_MultiRotation.h
21// Created: 30 Jan 2017
22// Author: Clarisse Genrault (CEA)
23
24#ifndef FEATURESPLUGIN_MULTIROTATION_H_
25#define FEATURESPLUGIN_MULTIROTATION_H_
26
27#include <FeaturesPlugin.h>
28
29#include <GeomAlgoAPI_Rotation.h>
30#include <GeomAlgoAPI_Translation.h>
31
32#include <ModelAPI_Feature.h>
33
41{
42 public:
44 inline static const std::string& ID()
45 {
46 static const std::string MY_MULTIROTATION_ID("AngularCopy");
47 return MY_MULTIROTATION_ID;
48 }
49
51 inline static const std::string& OBJECTS_LIST_ID()
52 {
53 static const std::string MY_OBJECTS_LIST_ID("main_objects");
54 return MY_OBJECTS_LIST_ID;
55 }
56
58 inline static const std::string& AXIS_ANGULAR_ID()
59 {
60 static const std::string MY_AXIS_ANGULAR_ID("axis_angular");
61 return MY_AXIS_ANGULAR_ID;
62 }
63
65 inline static const std::string& USE_ANGULAR_STEP_ID()
66 {
67 static const std::string MY_USE_ANGULAR_STEP_ID("use_step_angular");
68 return MY_USE_ANGULAR_STEP_ID;
69 }
70
72 inline static const std::string& STEP_ANGULAR_ID()
73 {
74 static const std::string MY_STEP_ANGULAR_ID("step_angular");
75 return MY_STEP_ANGULAR_ID;
76 }
77
79 inline static const std::string& NB_COPIES_ANGULAR_ID()
80 {
81 static const std::string MY_NB_COPIES_ANGULAR_ID("nb_angular");
82 return MY_NB_COPIES_ANGULAR_ID;
83 }
84
86 inline static const std::string& USE_RADIAL_DIR_ID()
87 {
88 static const std::string MY_USE_RADIAL_DIR_ID("use_radial_dir");
89 return MY_USE_RADIAL_DIR_ID;
90 }
91
93 inline static const std::string& STEP_RADIAL_ID()
94 {
95 static const std::string MY_STEP_RADIAL_ID("step_radial");
96 return MY_STEP_RADIAL_ID;
97 }
98
100 inline static const std::string& NB_COPIES_RADIAL_ID()
101 {
102 static const std::string MY_NB_COPIES_RADIAL_ID("nb_radial");
103 return MY_NB_COPIES_RADIAL_ID;
104 }
105
107 FEATURESPLUGIN_EXPORT virtual const std::string& getKind()
108 {
109 static std::string MY_KIND = FeaturesPlugin_MultiRotation::ID();
110 return MY_KIND;
111 }
112
114 FEATURESPLUGIN_EXPORT virtual void execute();
115
117 FEATURESPLUGIN_EXPORT virtual void initAttributes();
118
121
122private:
125 bool paramsOfRotation(std::shared_ptr<GeomAPI_Ax1>& theAxis, double& theAngle, int& theQuantity);
126
128 void performRotation1D();
129
130#ifdef FEATURE_MULTIROTATION_TWO_DIRECTIONS
132 void performRotation2D();
133
134 void loadNamingDS2(std::list<std::shared_ptr<GeomAlgoAPI_Translation> > theListOfTranslationAlgo,
135 std::shared_ptr<ModelAPI_ResultBody> theResultBody,
136 std::shared_ptr<GeomAPI_Shape> theBaseShape);
137
138 void loadNamingDS3(std::list<std::shared_ptr<GeomAlgoAPI_Rotation> > theListOfRotationAlgo,
139 std::shared_ptr<ModelAPI_ResultBody> theResultBody,
140 std::shared_ptr<GeomAPI_Shape> theBaseShape, int nb);
141#endif
142};
143
144#endif // FEATURESPLUGIN_MULTIROTATION_H_
Feature that rotaes object around an axis an number of times.
Definition: FeaturesPlugin_MultiRotation.h:41
virtual FEATURESPLUGIN_EXPORT const std::string & getKind()
Definition: FeaturesPlugin_MultiRotation.h:107
static const std::string & NB_COPIES_ANGULAR_ID()
Attribute name of number of copies for angular.
Definition: FeaturesPlugin_MultiRotation.h:79
Multi-rotation kind.
Definition: FeaturesPlugin_MultiRotation.h:44
static const std::string & USE_ANGULAR_STEP_ID()
Attribute name for use angular step.
Definition: FeaturesPlugin_MultiRotation.h:65
static const std::string & STEP_RADIAL_ID()
Attribute name of radial step.
Definition: FeaturesPlugin_MultiRotation.h:93
static const std::string & NB_COPIES_RADIAL_ID()
Attribute name of number of copies for radial.
Definition: FeaturesPlugin_MultiRotation.h:100
virtual FEATURESPLUGIN_EXPORT void initAttributes()
Definition: FeaturesPlugin_MultiRotation.cpp:60
Attribute name of referenced objects.
Definition: FeaturesPlugin_MultiRotation.h:51
static const std::string & STEP_ANGULAR_ID()
Attribute name of step for the angular.
Definition: FeaturesPlugin_MultiRotation.h:72
virtual FEATURESPLUGIN_EXPORT void execute()
Definition: FeaturesPlugin_MultiRotation.cpp:92
static const std::string & USE_RADIAL_DIR_ID()
Attribute name for use radial dir.
Definition: FeaturesPlugin_MultiRotation.h:86
static const std::string & AXIS_ANGULAR_ID()
Attribute name of the angular direction.
Definition: FeaturesPlugin_MultiRotation.h:58
FeaturesPlugin_MultiRotation()
Definition: FeaturesPlugin_MultiRotation.cpp:55
