FeaturesPlugin_Translation Class Reference
Feature for translation objects along the axis. More...
#include <FeaturesPlugin_Translation.h>
Inheritance diagram for FeaturesPlugin_Translation:
virtual FEATURESPLUGIN_EXPORT const std::string & getKind ()
virtual FEATURESPLUGIN_EXPORT void execute ()
virtual FEATURESPLUGIN_EXPORT void initAttributes ()
 FeaturesPlugin_Translation ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Translation kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_BY_DISTANCE ()
 Attribute name for creation method "ByAxisAndDistance". More...
static const std::string & CREATION_METHOD_BY_DIMENSIONS ()
 Attribute name for creation method "ByDimensions". More...
static const std::string & CREATION_METHOD_BY_TWO_POINTS ()
 Attribute name for creation method "ByTwoPoints". More...
static const std::string & OBJECTS_LIST_ID ()
 Attribute name of referenced objects. More...
static const std::string & AXIS_OBJECT_ID ()
 Attribute name of an axis. More...
static const std::string & DISTANCE_ID ()
 Attribute name of distance. More...
static const std::string & DX_ID ()
 Attribute name of dimension in X. More...
static const std::string & DY_ID ()
 Attribute name of dimension in Y. More...
static const std::string & DZ_ID ()
 Attribute name of dimension in Z. More...
static const std::string & START_POINT_ID ()
 Attribute name of start point. More...
static const std::string & END_POINT_ID ()
 Attribute name of end point. More...
static std::string group ()
◆ FeaturesPlugin_Translation()
FeaturesPlugin_Translation::FeaturesPlugin_Translation ( )
◆ ID()
static const std::string & FeaturesPlugin_Translation::ID ( )
inlinestatic
Translation kind.
◆ CREATION_METHOD()
static const std::string & FeaturesPlugin_Translation::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_BY_DISTANCE()
static const std::string & FeaturesPlugin_Translation::CREATION_METHOD_BY_DISTANCE ( )
inlinestatic
◆ CREATION_METHOD_BY_DIMENSIONS()
static const std::string & FeaturesPlugin_Translation::CREATION_METHOD_BY_DIMENSIONS ( )
inlinestatic
◆ CREATION_METHOD_BY_TWO_POINTS()
static const std::string & FeaturesPlugin_Translation::CREATION_METHOD_BY_TWO_POINTS ( )
inlinestatic
◆ OBJECTS_LIST_ID()
static const std::string & FeaturesPlugin_Translation::OBJECTS_LIST_ID ( )
inlinestatic
◆ AXIS_OBJECT_ID()
static const std::string & FeaturesPlugin_Translation::AXIS_OBJECT_ID ( )
inlinestatic
◆ DISTANCE_ID()
static const std::string & FeaturesPlugin_Translation::DISTANCE_ID ( )
inlinestatic
◆ DX_ID()
static const std::string & FeaturesPlugin_Translation::DX_ID ( )
inlinestatic
◆ DY_ID()
static const std::string & FeaturesPlugin_Translation::DY_ID ( )
inlinestatic
◆ DZ_ID()
static const std::string & FeaturesPlugin_Translation::DZ_ID ( )
inlinestatic
◆ START_POINT_ID()
static const std::string & FeaturesPlugin_Translation::START_POINT_ID ( )
inlinestatic
◆ END_POINT_ID()
static const std::string & FeaturesPlugin_Translation::END_POINT_ID ( )
inlinestatic
◆ getKind()
virtual FEATURESPLUGIN_EXPORT const std::string & FeaturesPlugin_Translation::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_Translation::execute ( )
◆ initAttributes()
void FeaturesPlugin_Translation::initAttributes ( )
Implements ModelAPI_Object.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
