Feature for creation of a cylinder. More...
#include <PrimitivesPlugin_Cylinder.h>
| virtual PRIMITIVESPLUGIN_EXPORT const std::string & | getKind () |
| virtual PRIMITIVESPLUGIN_EXPORT void | execute () |
| virtual PRIMITIVESPLUGIN_EXPORT void | initAttributes () |
| PrimitivesPlugin_Cylinder () | |
| std::wstring | name () |
| Cylinder kind. More... | |
| static const std::string & | CREATION_METHOD () |
| Attribute name for creation method. More... | |
| static const std::string & | CREATION_METHOD_CYLINDER () |
| static const std::string & | CREATION_METHOD_CYLINDER_PORTION () |
| static const std::string & | BASE_POINT_ID () |
| Attribute name of the base point. More... | |
| static const std::string & | AXIS_ID () |
| Attribute name of the axis. More... | |
| static const std::string & | RADIUS_ID () |
| Attribute name of the radius. More... | |
| static const std::string & | HEIGHT_ID () |
| Attribute name of the height. More... | |
| static const std::string & | ANGLE_ID () |
| Attribute name of the angle. More... | |
Creates a cylinder from a radius, a height, an angle, a center point defaulting to the origin and an axis defaulting to OZ
| PrimitivesPlugin_Cylinder::PrimitivesPlugin_Cylinder | ( | ) |
inlinestatic |
Cylinder kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
