The Import Result feature allows the user to import one or several results from another Part. More...
#include <FeaturesPlugin_ImportResult.h>
| virtual void | execute () |
| virtual std::shared_ptr< ModelAPI_Feature > | addFeature (std::string theID) |
| Appends a feature. More... | |
| virtual int | numberOfSubs (bool forTree=false) const |
| virtual std::shared_ptr< ModelAPI_Feature > | subFeature (const int theIndex, bool forTree=false) |
| virtual int | subFeatureId (const int theIndex) const |
| virtual bool | isSub (ObjectPtr theObject) const |
| virtual void | removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature) |
| This method to inform that sub-feature is removed and must be removed from the internal data structures of the owner (the remove from the document will be done outside just after). More... | |
| FeaturesPlugin_ImportResult () | |
| virtual void | erase () |
| in addition removes all subs More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | FEATURES_ID () |
| All features (list of references) More... | |
| static const std::string & | OBJECTS () |
| Selection list attribute that contains all copied shapes selection. More... | |
inline |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
inlinestatic |
documents of Parts
Implements ModelAPI_Object.
Appends a feature.
Implements ModelAPI_CompositeFeature.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
