Feature for creation of a new constraint tangency between line and arc or between two circular arcs. More...
#include <SketchPlugin_ConstraintTangent.h>
| virtual void | execute () |
| virtual AISObjectPtr | getAISObject (AISObjectPtr thePrevious) |
| Returns the AIS preview. More... | |
| SketchPlugin_ConstraintTangent () | |
| virtual bool | isZeroValueAllowed () |
| Get if a constraint is able to have a zero numeric value. More... | |
| virtual void | setNumericValue (const double theValue) |
| Set numeric value to attribute VALUE() More... | |
| virtual double | getNumericValue () |
| Get numeric value of attribute VALUE() More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true if the feature is a copy of other feature. More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| virtual bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| std::wstring | name () |
| Equal constraint kind. More... | |
| static const std::string & | VALUE () |
| The value parameter for the constraint. More... | |
| static const std::string & | FLYOUT_VALUE_PNT () |
| The 2D value parameter for the constraint. More... | |
| static const std::string & | CONSTRAINT_ACTIVE () |
| State of constraint - Active - true, Suppressed - false. More... | |
| static const std::string & | ENTITY_A () |
| First entity for the constraint. More... | |
| static const std::string & | ENTITY_B () |
| Second entity for the constraint. More... | |
| static const std::string & | ENTITY_C () |
| Third entity for the constraint. More... | |
| static const std::string & | ENTITY_D () |
| Fourth entity for the constraint. More... | |
| static const std::string & | ATTRIBUTE (const int theNumber) |
| List of constraint attributes. More... | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
The used features must have shared vertex
This constraint has two attributes: SketchPlugin_Constraint::ENTITY_A() and SketchPlugin_Constraint::ENTITY_B()
| SketchPlugin_ConstraintTangent::SketchPlugin_ConstraintTangent | ( | ) |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
| theValue | new set value |
Reimplemented in SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_Point, and SketchPlugin_Projection.
inlineprotectedinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
