Feature for creation of a GDML Ellipsoid solid. More...
#include <GDMLPlugin_Ellipsoid.h>
| virtual GDMLPLUGIN_EXPORT const std::string & | getKind () |
| virtual GDMLPLUGIN_EXPORT void | execute () |
| virtual GDMLPLUGIN_EXPORT void | initAttributes () |
| GDMLPlugin_Ellipsoid () | |
| std::wstring | name () |
| Cone segment kind. More... | |
| static const std::string & | AX_ID () |
| attribute name of the inner radius at base of cone More... | |
| static const std::string & | BY_ID () |
| attribute name of the outer radius at base of cone More... | |
| static const std::string & | CZ_ID () |
| attribute name of the inner radius at top of cone More... | |
| static const std::string & | ZCUT1_ID () |
| attribute name of the outer radius at top of cone More... | |
| static const std::string & | USE_ZCUT1_ID () |
| static const std::string & | USE_ZCUT2_ID () |
| static const std::string & | ZCUT2_ID () |
| GDMLPlugin_Ellipsoid::GDMLPlugin_Ellipsoid | ( | ) |
inlinestatic |
Cone segment kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
