FeaturesPlugin_SharedFaces.h
1// Copyright (C) 2018-2026 CEA, EDF
20#ifndef FeaturesPlugin_SharedFaces_H_
21#define FeaturesPlugin_SharedFaces_H_
23#include <FeaturesPlugin_CommonSharedFaces.h>
24
28
30{
31public:
33 inline static const std::string& ID()
34 {
35 static const std::string MY_ID("Shared_faces_macro");
36 return MY_ID;
37 }
38
40 inline static const std::string& OBJECT_ID()
41 {
42 static const std::string MY_OBJECT_ID("main_object");
43 return MY_OBJECT_ID;
44 }
45
47 inline static const std::string& NUMBER_FACES_ID()
48 {
49 static const std::string MY_NUMBER_FACES_ID("number_shared_faces");
50 return MY_NUMBER_FACES_ID;
51 }
52
54 inline static const std::string& LIST_FACES_ID()
55 {
56 static const std::string MY_LIST_FACES_ID("group_list");
57 return MY_LIST_FACES_ID;
58 }
59
61 inline static const std::string& TRANSPARENCY_ID()
62 {
63 static const std::string MY_TRANSPARENCY_ID("transparency");
64 return MY_TRANSPARENCY_ID;
65 }
66
68 inline static const std::string& CREATE_GROUP_ID()
69 {
70 static const std::string MY_CREATE_GROUP_ID("create_group");
71 return MY_CREATE_GROUP_ID;
72 }
73
75 inline static const std::string& COMPUTE_ID()
76 {
77 static const std::string MY_COMPUTE_ID("compute");
78 return MY_COMPUTE_ID;
79 }
80
82 inline static const std::string& GROUP_NAME_ID()
83 {
84 static const std::string MY_GROUP_NAME_ID("group_name");
85 return MY_GROUP_NAME_ID;
86 }
87
89 virtual const std::string& getKind()
90 {
91 return ID();
92 }
93
95 FEATURESPLUGIN_EXPORT virtual void execute();
96
98 FEATURESPLUGIN_EXPORT virtual void initAttributes();
99
102 FEATURESPLUGIN_EXPORT virtual void attributeChanged(const std::string& theID);
103
105 FEATURESPLUGIN_EXPORT virtual bool isMacro() const { return true; }
106
109
110private:
112 virtual AttributePtr attributObject();
113
115 virtual AttributePtr attributListFaces();
116
118 virtual AttributePtr attributNumberFaces();
119
121 virtual AttributePtr attributIsCompute();
122
124 void createGroup();
125
127 void updateGroup();
128
130 FeaturePtr myCreateGroupFeature;
131};
132
133#endif
Feature to check the shared faces of solid.
Definition: FeaturesPlugin_CommonSharedFaces.h:35
Feature to check the shared faces of compsolid or compound.
Definition: FeaturesPlugin_SharedFaces.h:30
static const std::string & TRANSPARENCY_ID()
Attribute name for transparency.
Definition: FeaturesPlugin_SharedFaces.h:61
FeaturesPlugin_SharedFaces()
Definition: FeaturesPlugin_SharedFaces.cpp:36
static const std::string & COMPUTE_ID()
Attribute name for indicate to launch the algo.
Definition: FeaturesPlugin_SharedFaces.h:75
static const std::string & CREATE_GROUP_ID()
Attribute name for checkbox create group.
Definition: FeaturesPlugin_SharedFaces.h:68
Definition: FeaturesPlugin_SharedFaces.h:89
virtual FEATURESPLUGIN_EXPORT bool isMacro() const
Reimplemented from ModelAPI_Feature::isMacro(). Returns true.
Definition: FeaturesPlugin_SharedFaces.h:105
virtual FEATURESPLUGIN_EXPORT void attributeChanged(const std::string &theID)
Definition: FeaturesPlugin_SharedFaces.cpp:142
virtual FEATURESPLUGIN_EXPORT void initAttributes()
Definition: FeaturesPlugin_SharedFaces.cpp:41
static const std::string & LIST_FACES_ID()
Attribute name for z coordinate.
Definition: FeaturesPlugin_SharedFaces.h:54
Shared faces kind.
Definition: FeaturesPlugin_SharedFaces.h:33
static const std::string & NUMBER_FACES_ID()
Attribute name for number of faces.
Definition: FeaturesPlugin_SharedFaces.h:47
virtual FEATURESPLUGIN_EXPORT void execute()
Definition: FeaturesPlugin_SharedFaces.cpp:82
static const std::string & GROUP_NAME_ID()
Attribute name for group name.
Definition: FeaturesPlugin_SharedFaces.h:82
static const std::string & OBJECT_ID()
Attribute name for object selected.
Definition: FeaturesPlugin_SharedFaces.h:40
