SketchPlugin_ConstraintLength.h
20#ifndef SketchPlugin_ConstraintLength_H_
21#define SketchPlugin_ConstraintLength_H_
23#include "SketchPlugin.h"
24#include "SketchPlugin_ConstraintBase.h"
25#include "SketchPlugin_Sketch.h"
26
27#include <GeomAPI_ICustomPrs.h>
28
29#include <list>
30
31class GeomAPI_Pnt2d;
33
43{
44 public:
46 inline static const std::string& ID()
47 {
48 static const std::string MY_CONSTRAINT_LENGTH_ID("SketchConstraintLength");
49 return MY_CONSTRAINT_LENGTH_ID;
50 }
51
53 SKETCHPLUGIN_EXPORT virtual const std::string& getKind()
54 {
55 static std::string MY_KIND = SketchPlugin_ConstraintLength::ID();
56 return MY_KIND;
57 }
58
60 inline static const std::string& LOCATION_TYPE_ID()
61 {
62 static const std::string MY_LOCATION_TYPE_ID("LocationType");
63 return MY_LOCATION_TYPE_ID;
64 }
65
67 SKETCHPLUGIN_EXPORT virtual void execute();
68
72 SKETCHPLUGIN_EXPORT virtual bool compute(const std::string& theAttributeId);
73
75 SKETCHPLUGIN_EXPORT virtual void initAttributes();
76
78 SKETCHPLUGIN_EXPORT virtual void colorConfigInfo(std::string& theSection, std::string& theName,
79 std::string& theDefault);
80
82 SKETCHPLUGIN_EXPORT virtual AISObjectPtr getAISObject(AISObjectPtr thePrevious);
83
86 SKETCHPLUGIN_EXPORT virtual void attributeChanged(const std::string& theID);
87
90
94 bool computeLenghtValue(double& theValue);
95
97 inline bool isZeroValueAllowed() override
98 {
99 return false;
100 }
101
102private:
104 bool getPoints(
105 std::shared_ptr<GeomAPI_Pnt>& thePoint1, std::shared_ptr<GeomAPI_Pnt>& thePoint2,
106 std::shared_ptr<GeomDataAPI_Point2D>& theStartPoint,
107 std::shared_ptr<GeomDataAPI_Point2D>& theEndPoint);
108
109private:
110 bool myFlyoutUpdate;
111};
112
113#endif
Feature for creation of a new constraint between other features.
Definition: SketchPlugin_ConstraintBase.h:56
Feature for creation of a new constraint which defines a length of a line segment.
Definition: SketchPlugin_ConstraintLength.h:43
static const std::string & LOCATION_TYPE_ID()
attribute name of dimension location type
Definition: SketchPlugin_ConstraintLength.h:60
bool computeLenghtValue(double &theValue)
Computes distance between length point attributes.
Definition: SketchPlugin_ConstraintLength.cpp:129
Definition: SketchPlugin_ConstraintLength.cpp:78
virtual void colorConfigInfo(std::string &theSection, std::string &theName, std::string &theDefault)
Returns the parameters of color definition in the resources config manager.
Definition: SketchPlugin_ConstraintLength.cpp:70
Length constraint kind.
Definition: SketchPlugin_ConstraintLength.h:46
Get if a constraint is able to have a zero numeric value.
Definition: SketchPlugin_ConstraintLength.h:97
virtual void attributeChanged(const std::string &theID)
Definition: SketchPlugin_ConstraintLength.cpp:177
SketchPlugin_ConstraintLength()
Definition: SketchPlugin_ConstraintLength.cpp:49
Returns the AIS preview.
Definition: SketchPlugin_ConstraintLength.cpp:165
Definition: SketchPlugin_ConstraintLength.cpp:54
virtual bool compute(const std::string &theAttributeId)
Definition: SketchPlugin_ConstraintLength.cpp:104
Definition: SketchPlugin_ConstraintLength.h:53
