Feature for creation of a new constraint between other features. More...
#include <SketchPlugin_ConstraintBase.h>
| virtual bool | isZeroValueAllowed () |
| Get if a constraint is able to have a zero numeric value. More... | |
| virtual void | setNumericValue (const double theValue) |
| Set numeric value to attribute VALUE() More... | |
| virtual double | getNumericValue () |
| Get numeric value of attribute VALUE() More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true if the feature is a copy of other feature. More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| virtual bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| virtual const std::string & | getKind ()=0 |
| Returns the unique kind of a feature (like "Point") More... | |
| virtual void | execute ()=0 |
| std::wstring | name () |
| virtual void | initAttributes ()=0 |
| Request for initialization of data model of the object: adding all attributes. More... | |
| virtual AISObjectPtr | getAISObject (AISObjectPtr thePrevious)=0 |
| Returns the AIS preview. More... | |
| static const std::string & | VALUE () |
| The value parameter for the constraint. More... | |
| static const std::string & | FLYOUT_VALUE_PNT () |
| The 2D value parameter for the constraint. More... | |
| static const std::string & | CONSTRAINT_ACTIVE () |
| State of constraint - Active - true, Suppressed - false. More... | |
| static const std::string & | ENTITY_A () |
| First entity for the constraint. More... | |
| static const std::string & | ENTITY_B () |
| Second entity for the constraint. More... | |
| static const std::string & | ENTITY_C () |
| Third entity for the constraint. More... | |
| static const std::string & | ENTITY_D () |
| Fourth entity for the constraint. More... | |
| static const std::string & | ATTRIBUTE (const int theNumber) |
| List of constraint attributes. More... | |
| SketchPlugin_ConstraintBase () | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
Some feature's methods implemented here as dummy to Base class for all constraints.
inlineprotected |
inlinestaticinherited |
inlinevirtualinherited |
| theValue | new set value |
Reimplemented in SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_Point, and SketchPlugin_Projection.
inlineprotectedinherited |
pure virtualinherited |
Implemented in BuildPlugin_Compound, BuildPlugin_CompSolid, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupAddition, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupShape, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportPart, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_Chamfer, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionCut, FeaturesPlugin_ExtrusionFuse, FeaturesPlugin_Fillet, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionCut, FeaturesPlugin_RevolutionFuse, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, FiltersPlugin_Selection, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_Arc, SketchPlugin_BSpline, SketchPlugin_BSplinePeriodic, SketchPlugin_Circle, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceHorizontal, SketchPlugin_ConstraintDistanceVertical, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_CurveFitting, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_Fillet, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroBSplinePeriodic, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Point, SketchPlugin_Projection, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_Split, SketchPlugin_Trim, ExchangePlugin_Import, ExchangePlugin_Import_Image, ExchangePlugin_ImportFeature, ExchangePlugin_Import_ImageFeature, and ExchangePlugin_ImportFeatureBase.
inlineinherited |
Implements ModelAPI_Object.
Implemented in BuildPlugin_Compound, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupAddition, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupShape, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportPart, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_BoundingBoxBase, FeaturesPlugin_CommonSharedFaces, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionCut, FeaturesPlugin_ExtrusionFuse, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionCut, FeaturesPlugin_RevolutionFuse, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, FeaturesPlugin_VersionedChFi, FiltersPlugin_Selection, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceAlongDir, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_CurveFitting, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_Fillet, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Point, SketchPlugin_Projection, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_Split, SketchPlugin_Trim, ExchangePlugin_Import, ExchangePlugin_Import_Image, ExchangePlugin_ImportFeature, ExchangePlugin_Import_ImageFeature, ExchangePlugin_ImportBase, and ExchangePlugin_ImportFeatureBase.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
Implemented in BuildPlugin_Compound, BuildPlugin_CompSolid, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupMerge, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportBase, ExchangePlugin_Import, ExchangePlugin_ImportFeatureBase, ExchangePlugin_ImportFeature, ExchangePlugin_ImportPart, FeaturesPlugin_Boolean, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_Chamfer, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionBoolean, FeaturesPlugin_Fillet, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionBoolean, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, Model_ResultBody, Model_ResultParameter, Model_ResultPart, ModelAPI_Folder, ModelAPI_Result, ModelAPI_ResultField::ModelAPI_FieldStep, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceAlongDir, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_SketchEntity, SketchPlugin_Split, SketchPlugin_Trim, FiltersPlugin_Selection, and ModelAPI_ResultParameter.
| thePrevious | - defines a presentation if it was created previously |
Implemented in FeaturesPlugin_Measurement, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceAlongDir, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_CurveFitting, SketchPlugin_Fillet, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Split, and SketchPlugin_Trim.
