Manager of objects of the document. More...
#include <Model_Objects.h>
| void | addFeature (FeaturePtr theFeature, const FeaturePtr theAfterThis) |
| Registers the feature in the data structure. More... | |
| void | refsToFeature (FeaturePtr theFeature, std::set< FeaturePtr > &theRefs, const bool isSendError=true) |
| Return a list of features, which refers to the feature. More... | |
| void | removeFeature (FeaturePtr theFeature) |
| Removes the feature from the document (with result) More... | |
| void | moveFeature (FeaturePtr theMoved, FeaturePtr theAfterThis) |
| Moves the feature to make it after the given one in the history. More... | |
| FeaturePtr | feature (TDF_Label theLabel) const |
| Returns the existing feature by the label. More... | |
| ObjectPtr | object (TDF_Label theLabel) |
| Returns the existing object: result or feature. More... | |
| std::shared_ptr< ModelAPI_Object > | objectByName (const std::string &theGroupID, const std::wstring &theName) |
| Returns the first found object in the group by the object name. More... | |
| ResultPtr | findByName (const std::wstring theName) |
| Returns the result by the result name. More... | |
| const int | index (std::shared_ptr< ModelAPI_Object > theObject, const bool theAllowFolder=false) |
| Returns the object index in the group. More... | |
| ObjectPtr | object (const std::string &theGroupID, const int theIndex, const bool theAllowFolder=false) |
| Returns the feature in the group by the index (started from zero) More... | |
| int | size (const std::string &theGroupID, const bool theAllowFolder=false) |
| Returns the number of features in the group. More... | |
| std::shared_ptr< ModelAPI_Object > | parent (const std::shared_ptr< ModelAPI_Object > theChild) |
| Returns the parent object of this child. More... | |
| void | allResults (const std::string &theGroupID, std::list< ResultPtr > &theResults) |
| Returns all (and disabled) results of the given type. More... | |
| int | numInternalFeatures () |
| Returns the number of all features: in the history or not. More... | |
| std::shared_ptr< ModelAPI_Feature > | internalFeature (const int theIndex) |
| Returns the feature by zero-based index: features in the history or not. More... | |
| std::shared_ptr< ModelAPI_ResultConstruction > | createConstruction (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0) |
| Creates a construction result. More... | |
| std::shared_ptr< ModelAPI_ResultBody > | createBody (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0, const std::wstring &theNameShape=L"") |
| Creates a body result. More... | |
| std::shared_ptr< ModelAPI_ResultPart > | createPart (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0) |
| Creates a part result. More... | |
| std::shared_ptr< ModelAPI_ResultPart > | copyPart (const std::shared_ptr< ModelAPI_ResultPart > &theOrigin, const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0) |
| Copies a part result, keeping the reference to origin. More... | |
| std::shared_ptr< ModelAPI_ResultGroup > | createGroup (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0) |
| Creates a group result. More... | |
| std::shared_ptr< ModelAPI_ResultField > | createField (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0) |
| Creates a field result. More... | |
| std::shared_ptr< ModelAPI_ResultParameter > | createParameter (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theIndex=0) |
| Creates a parameter result. More... | |
| std::shared_ptr< ModelAPI_Feature > | feature (const std::shared_ptr< ModelAPI_Result > &theResult) |
| Returns a feature by result (owner of result) More... | |
| std::shared_ptr< ModelAPI_Folder > | createFolder (const std::shared_ptr< ModelAPI_Feature > &theBeforeThis) |
| Creates a folder (group of the features in the object browser) More... | |
| void | removeFolder (std::shared_ptr< ModelAPI_Folder > theFolder) |
| Removes the folder from the document (all features in the folder will be kept). More... | |
| std::shared_ptr< ModelAPI_Folder > | findFolder (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures, const bool theBelow) |
| Search a folder applicable for the list of features (it means the list of features stored in the folder should be consequential) More... | |
| std::shared_ptr< ModelAPI_Folder > | findContainingFolder (const std::shared_ptr< ModelAPI_Feature > &theFeature, int &theIndexInFolder) |
| Search a folder containing the given feature. More... | |
| bool | moveToFolder (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures, const std::shared_ptr< ModelAPI_Folder > &theFolder) |
| Add a list of features to the folder. More... | |
| bool | removeFromFolder (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures, const bool theBefore=true) |
| Remove features from the folder. More... | |
| void | storeSubShapeWithColor (std::shared_ptr< ModelAPI_Result > theResult, std::shared_ptr< GeomAPI_Shape > theSubShape, const std::vector< int > &theColor) |
| Store theSubShape in theResult, set color attribute to theSubShape. More... | |
| std::vector< int > | getSubShapeColor (std::shared_ptr< ModelAPI_Result > theResult, std::shared_ptr< GeomAPI_Shape > theSubShape) |
| Get color of subshape. More... | |
| void | getColoredSubShapes (const std::shared_ptr< ModelAPI_Result > theResult, std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &theColoredSubShapes) |
| Get colored subshapes from result. More... | |
| void | removeSubShapeColors (const std::shared_ptr< ModelAPI_Result > theResult) |
| Forget subshape colors. More... | |
| void | setOwner (DocumentPtr theDoc) |
| Sets the owner of this manager. More... | |
| DocumentPtr | owner () |
| Returns the owner of this manager. More... | |
| virtual | ~Model_Objects () |
| Deletes all managed features with emitting of corresponded signal. More... | |
| TDF_Label | featuresLabel () const |
| Returns (creates if needed) the features label. More... | |
| TDF_Label | coloredSubShapesLabel (std::shared_ptr< ModelAPI_Result > theResult) const |
| Returns (creates if needed) the label of colored subshapes of the result. More... | |
| TDF_Label | coloredSubShapeLabel (TDF_Label &theSubShapesLabel, const int theSubShapeIndex) |
| Returns (creates if needed) the label of colored subshape by index. More... | |
| const int | coloredSubShapeIndex (std::shared_ptr< ModelAPI_Result > theResult, std::shared_ptr< GeomAPI_Shape > theSubShape) |
| Returns the index of the colored subshape in the result. More... | |
| void | setUniqueName (FeaturePtr theFeature) |
| Initializes feature with a unique name in this group (unique name is generated as feature type + "_" + index. More... | |
| void | setUniqueName (FolderPtr theFolder) |
| Initializes the folder with an unique name ("Folder_" + index) More... | |
| void | synchronizeFeatures (const TDF_LabelList &theUpdated, const bool theUpdateReferences, const bool theOpen, const bool theExecuteFeatures, const bool theFlush) |
| Synchronizes myFeatures list with the updated document. More... | |
| void | synchronizeBackRefs () |
| Synchronizes the BackReferences list in Data of Features and Results. More... | |
| Model_Objects (TDF_Label theMainLab) | |
| Creates manager on the OCAF document main label. More... | |
| void | initData (ObjectPtr theObj, TDF_Label theLab, const int theTag) |
| Initializes the data fields of the feature. More... | |
| void | storeResult (std::shared_ptr< ModelAPI_Data > theFeatureData, std::shared_ptr< ModelAPI_Result > theResult, const int theResultIndex=0, const std::wstring &theNameShape=L"") |
| Allows to store the result in the data tree of the document (attaches 'data' of result to tree) More... | |
| TDF_Label | resultLabel (const std::shared_ptr< ModelAPI_Data > &theFeatureData, const int theResultIndex) |
| returns the label of result by index; creates this label if it was not created before More... | |
| void | updateResults (FeaturePtr theFeature, std::set< FeaturePtr > &theProcessed) |
| Updates the results list of the feature basing on the current data tree theProcessed is used to avoid update twice (since the function is recursive) More... | |
| void | updateHistory (const std::shared_ptr< ModelAPI_Object > theObject) |
| Internally makes document know that feature was removed or added in history after creation. More... | |
| void | updateHistory (const std::string theGroup) |
| void | clearHistory (ObjectPtr theObj) |
| Clears the history arrays related to this object. More... | |
| void | createHistory (const std::string &theGroupID) |
| Creates the history: up to date with the current state. More... | |
| FeaturePtr | nextFeature (FeaturePtr theCurrent, int &theIndex, const bool theReverse=false) |
| Returns the next (from the history point of view) feature, any: invisible or disabled. More... | |
| FeaturePtr | firstFeature () |
| Returns to the first (from the history point of view) feature, any: invisible or disabled. More... | |
| FeaturePtr | lastFeature () |
| Returns to the last (from the history point of view) feature, any: invisible or disabled. More... | |
| bool | isLater (FeaturePtr theLater, FeaturePtr theCurrent) const |
| Returns true if theLater is in history of features creation later than theCurrent. More... | |
| TDF_Label | nextLabel (TDF_Label theCurrent, int &theIndex, const bool theReverse=false) |
| Returns the next or previous label. More... | |
| std::string | featureResultGroup (FeaturePtr theFeature) |
| Returns the result group identifier of the given feature (for this at least one result must be created before) More... | |
| std::list< std::shared_ptr< ModelAPI_Feature > > | allFeatures () |
| Returns all features of the document including the hidden features which are not in history. More... | |
| std::list< std::shared_ptr< ModelAPI_Object > > | allObjects () |
| Returns all objects of the document including the hidden features which are not in history. More... | |
| void | synchronizeBackRefsForObject (const std::set< std::shared_ptr< ModelAPI_Attribute > > &theNewRefs, ObjectPtr theObject) |
| synchronizes back references for the given object basing on the collected data More... | |
| virtual void | eraseAllFeatures () |
| Just removes all features without touching the document data (to be able undo) More... | |
| bool | hasCustomName (DataPtr theFeatureData, ResultPtr theResult, int theResultIndex, std::wstring &theParentName) const |
| const ObjectPtr & | folder (TDF_Label theLabel) const |
| Return object representing a folder or empty pointer. More... | |
Normally one this class corresponds to one document and just helper to manage objects (ModelAPI_Objects) inside of the document on the level of data storage.
protected |
0:1:2 - where features are located 0:1:2:N:1 - data of the feature N 0:1:2:N:2:K:1 - data of the K result of the feature N 0:1:2:N:2:K:2:M:1 - data of the M sub-shape of the K result of the feature N
| void Model_Objects::addFeature | ( | FeaturePtr | theFeature, |
| const FeaturePtr | theAfterThis | ||
| theFeature | feature that must be added to the data structure |
| theAfterThis | the feature will be added after this feature; if it is null, the added feature will be the first |
| void Model_Objects::refsToFeature | ( | FeaturePtr | theFeature, |
| std::set< FeaturePtr > & | theRefs, | ||
| const bool | isSendError = true |
| theFeature | a feature |
| theRefs | a list of reference features |
| isSendError | a flag whether the error message should be send |
| void Model_Objects::removeFeature | ( | FeaturePtr | theFeature | ) |
| theFeature | a removed feature |
| void Model_Objects::moveFeature | ( | FeaturePtr | theMoved, |
| FeaturePtr Model_Objects::feature | ( | TDF_Label | theLabel | ) | const |
| theLabel | base label of the feature |
| ObjectPtr Model_Objects::object | ( | TDF_Label | theLabel | ) |
| theLabel | base label of the object |
| std::shared_ptr< ModelAPI_Object > Model_Objects::objectByName | ( | const std::string & | theGroupID, |
| const std::wstring & | theName | ||
| theGroupID | group that contains an object |
| theName | name of the object to search |
| ResultPtr Model_Objects::findByName | ( | const std::wstring | theName | ) |
| const int Model_Objects::index | ( | std::shared_ptr< ModelAPI_Object > | theObject, |
| const bool | theAllowFolder = false |
Object must be visible. Otherwise returns -1.
| theObject | object of this document |
| theAllowFolder | take into account grouping feature by folders |
| ObjectPtr Model_Objects::object | ( | const std::string & | theGroupID, |
| const int | theIndex, | ||
| theGroupID | group that contains a feature |
| theIndex | zero-based index of feature in the group |
| int Model_Objects::size | ( | const std::string & | theGroupID, |
| theGroupID | group of objects |
| std::shared_ptr< ModelAPI_Object > Model_Objects::parent | ( | const std::shared_ptr< ModelAPI_Object > | theChild | ) |
This may be result or feature, parent of a top result. Fast method, that uses internal data structure specifics.
| void Model_Objects::allResults | ( | const std::string & | theGroupID, |
| std::list< ResultPtr > & | theResults | ||
Not fast method (iterates all features).
| int Model_Objects::numInternalFeatures | ( | ) |
| std::shared_ptr< ModelAPI_Feature > Model_Objects::internalFeature | ( | const int | theIndex | ) |
| std::shared_ptr< ModelAPI_ResultConstruction > Model_Objects::createConstruction | ( | const std::shared_ptr< ModelAPI_Data > & | theFeatureData, |
| const int | theIndex = 0 |
| std::shared_ptr< ModelAPI_ResultBody > Model_Objects::createBody | ( | const std::shared_ptr< ModelAPI_Data > & | theFeatureData, |
| const int | theIndex = 0, |
| const std::wstring & | theNameShape = L"" |
| std::shared_ptr< ModelAPI_ResultPart > Model_Objects::createPart | ( | const std::shared_ptr< ModelAPI_Data > & | theFeatureData, |
| std::shared_ptr< ModelAPI_ResultPart > Model_Objects::copyPart | ( | const std::shared_ptr< ModelAPI_ResultPart > & | theOrigin, |
| const std::shared_ptr< ModelAPI_Data > & | theFeatureData, | ||
| std::shared_ptr< ModelAPI_ResultGroup > Model_Objects::createGroup | ( | const std::shared_ptr< ModelAPI_Data > & | theFeatureData, |
| std::shared_ptr< ModelAPI_ResultField > Model_Objects::createField | ( | const std::shared_ptr< ModelAPI_Data > & | theFeatureData, |
| std::shared_ptr< ModelAPI_ResultParameter > Model_Objects::createParameter | ( | const std::shared_ptr< ModelAPI_Data > & | theFeatureData, |
| std::shared_ptr< ModelAPI_Feature > Model_Objects::feature | ( | const std::shared_ptr< ModelAPI_Result > & | theResult | ) |
| std::shared_ptr< ModelAPI_Folder > Model_Objects::createFolder | ( | const std::shared_ptr< ModelAPI_Feature > & | theBeforeThis | ) |
| void Model_Objects::removeFolder | ( | std::shared_ptr< ModelAPI_Folder > | theFolder | ) |
| std::shared_ptr< ModelAPI_Folder > Model_Objects::findFolder | ( | const std::list< std::shared_ptr< ModelAPI_Feature > > & | theFeatures, |
| const bool | theBelow | ||
| theFeatures | list of features to be added to folder |
| theBelow | search the folder below the features (if false, search above) |
| FolderPtr Model_Objects::findContainingFolder | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| int & | theIndexInFolder | ||
Additionally calculates a zero-based index of the feature in this folder.
| theFeature | feature to search |
| theIndexInFolder | zero-based index in the folder or -1 if the feature is top-level. |
| bool Model_Objects::moveToFolder | ( | const std::list< std::shared_ptr< ModelAPI_Feature > > & | theFeatures, |
| const std::shared_ptr< ModelAPI_Folder > & | theFolder | ||
The correctness of the adding is not performed (such checks have been done in corresponding find.. method).
true if the movement is successful | bool Model_Objects::removeFromFolder | ( | const std::list< std::shared_ptr< ModelAPI_Feature > > & | theFeatures, |
| const bool | theBefore = true |
| theFeatures | list of features to be removed |
| theBefore | extract features before the folder (this parameter is applicable only when all features in the folder are taking out, in other cases the direction is taken automatically) |
true if the features have been moved out | void Model_Objects::storeSubShapeWithColor | ( | std::shared_ptr< ModelAPI_Result > | theResult, |
| std::shared_ptr< GeomAPI_Shape > | theSubShape, | ||
| const std::vector< int > & | theColor | ||
| std::vector< int > Model_Objects::getSubShapeColor | ( | std::shared_ptr< ModelAPI_Result > | theResult, |
| std::shared_ptr< GeomAPI_Shape > | theSubShape | ||
| void Model_Objects::getColoredSubShapes | ( | const std::shared_ptr< ModelAPI_Result > | theResult, |
| std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > & | theColoredSubShapes | ||
| void Model_Objects::removeSubShapeColors | ( | const std::shared_ptr< ModelAPI_Result > | theResult | ) |
| void Model_Objects::setOwner | ( | DocumentPtr | theDoc | ) |
inline |
protected |
protected |
protected |
protected |
| theResult | result |
| theSubShape | result subshape |
protected |
protected |
protected |
| theUpdated | list of labels that are marked as modified, so features must be also |
| theUpdateReferences | causes the update of back-references |
| theExecuteFeatures | requires re-execute modified persistent features (not needed on undo/redo/abort/open) |
| theOpen | - on open nothing must be re-executed, except not persistent results |
| theFlush | makes flush all events in the end of all modifications of this method |
protected |
protected |
protected |
protected |
protected |
protected |
protected |
protected |
protected |
protected |
| theCurrent | previous to the resulting feature |
| theReverse | if it is true, iterates in reversed order (next becomes previous) |
| theIndex | may be used for optimization: index of theCurrent in references array |
protected |
protected |
protected |
protected |
| theCurrent | given label |
protected |
protected |
Not very fast method, for calling once, not in big cycles.
protected |
protected |
protectedvirtual |
protected |
