ModelAPI_ResultPart Class Referenceabstract
The Part document, result of a creation of new part feature. More...
#include <ModelAPI_ResultPart.h>
Inheritance diagram for ModelAPI_ResultPart:
virtual std::shared_ptr< ModelAPI_Document > partDoc ()=0
 Returns the part-document of this result. More...
virtual std::shared_ptr< ModelAPI_ResultPart > original ()=0
 Returns the original part result: for transformation features results this is the original Part feature result. More...
virtual void activate ()=0
 Sets this document as current and if it is not loaded yet, loads it. More...
virtual bool isActivated ()=0
 Returns true if document is activated (loaded into the memory) More...
virtual std::wstring nameInPart (const std::shared_ptr< GeomAPI_Shape > &theShape, int &theIndex)=0
 Returns the name of the shape inside of the part. More...
virtual bool updateInPart (const int theIndex)=0
 Updates the selection inside of the part by the selection index. More...
virtual void setTrsf (std::shared_ptr< ModelAPI_Result > theThis, const std::shared_ptr< GeomAPI_Trsf > &theTransformation)=0
 Applies the additional transformation of the part. More...
virtual std::shared_ptr< GeomAPI_Trsf > summaryTrsf ()=0
 Returns the summary transformations of all references to the origin. More...
virtual std::shared_ptr< GeomAPI_Shape > shapeInPart (const std::wstring &theName, const std::string &theType, int &theIndex)=0
 Returns the shape by the name in the part. More...
virtual void setSubShapeColor (const std::shared_ptr< GeomAPI_Shape > &theShape, const std::vector< int > &theColor)=0
 Set color on subshape. More...
virtual void getSubShapeColor (const std::shared_ptr< GeomAPI_Shape > &theShape, std::vector< int > &theColor)=0
 Get subshape color. More...
virtual void getColoredSubShapes (std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &theColoredShapes)=0
 Get colored subshapes from result. More...
virtual void removeSubShapeColors ()=0
 Forget subshapes colors. More...
virtual bool combineGeometrical (const int theIndex, std::wstring &theNewName)=0
 Updates the selection inside of the part as a geometrical selection. More...
virtual std::shared_ptr< GeomAPI_Shape > selectionValue (const int theIndex)=0
 Returns the shape selected in the selection index. More...
virtual void updateShape ()=0
 Updates the shape-result of the part (called on Part feature execution) More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > selection ()=0
 Return Attribute selection. More...
virtual void loadPart ()=0
 Loading the part from file. More...
virtual bool isConcealed ()
 Returns true if the result is concealed from the data tree (referenced by other objects) More...
virtual void setIsConcealed (const bool theValue, const bool theForced=false)
 Sets the result as concealed in the data tree (referenced by other objects) More...
virtual bool setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag)
 Enables/disables the result. More...
virtual bool isDisabled ()
 Returns the result is disabled or not. More...
 Request for initialization of data model of the result: adding all attributes. More...
virtual std::shared_ptr< GeomAPI_Shape > shape ()
 Returns the shape-result produced by this feature (or null if no shapes) More...
 Returns all the vertices of this result. More...
 Returns all the edges of this result. More...
 Returns all the wires of this result. More...
 Returns all the faces of this result. More...
 Returns all the shells of this result. More...
 Returns all the solids of this result. More...
 On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More...
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
static std::string group ()
static const std::string & DOC_REF ()
 part document reference attribute More...
static const std::string & DEFAULT_COLOR ()
 default color for a result body More...
static const std::string & COLOR_ID ()
 Reference to the color of the result. More...
static const std::string & DEFLECTION_ID ()
 Reference to the deflection of the result. More...
static const std::string & TRANSPARENCY_ID ()
 Reference to the transparency of the result. More...
static const std::string & ISO_LINES_ID ()
static const std::string & SHOW_ISO_LINES_ID ()
static const std::string & SHOW_EDGES_DIRECTION_ID ()
static const std::string & BRING_TO_FRONT_ID ()
 Reference to the BringToFront flag of the result. More...
virtual void init ()
virtual void erase ()
 removes all fields from this feature More...
bool myIsDisabled
 the result is disabled: removed for the user, but keeps the general info More...
This result leaves without feature: no parametricity for this element, only add/remove, undo/redo.
◆ groupName()
std::string ModelAPI_ResultPart::groupName ( )
Implements ModelAPI_Object.
◆ group()
static std::string ModelAPI_ResultPart::group ( )
inlinestatic
◆ DOC_REF()
static const std::string & ModelAPI_ResultPart::DOC_REF ( )
inlinestatic
◆ DEFAULT_COLOR()
static const std::string & ModelAPI_ResultPart::DEFAULT_COLOR ( )
inlinestatic
◆ partDoc()
virtual std::shared_ptr< ModelAPI_Document > ModelAPI_ResultPart::partDoc ( )
pure virtual
Implemented in Model_ResultPart.
◆ original()
virtual std::shared_ptr< ModelAPI_ResultPart > ModelAPI_ResultPart::original ( )
pure virtual
◆ activate()
virtual void ModelAPI_ResultPart::activate ( )
pure virtual
◆ isActivated()
virtual bool ModelAPI_ResultPart::isActivated ( )
pure virtual
◆ nameInPart()
virtual std::wstring ModelAPI_ResultPart::nameInPart ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
int &  theIndex
pure virtual
◆ updateInPart()
virtual bool ModelAPI_ResultPart::updateInPart ( const int  theIndex)
pure virtual
◆ setTrsf()
virtual void ModelAPI_ResultPart::setTrsf ( std::shared_ptr< ModelAPI_Result >  theThis,
const std::shared_ptr< GeomAPI_Trsf > &  theTransformation
pure virtual
◆ summaryTrsf()
virtual std::shared_ptr< GeomAPI_Trsf > ModelAPI_ResultPart::summaryTrsf ( )
pure virtual
◆ shapeInPart()
virtual std::shared_ptr< GeomAPI_Shape > ModelAPI_ResultPart::shapeInPart ( const std::wstring &  theName,
const std::string &  theType,
int &  theIndex
pure virtual
◆ setSubShapeColor()
virtual void ModelAPI_ResultPart::setSubShapeColor ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
const std::vector< int > &  theColor
pure virtual
◆ getSubShapeColor()
virtual void ModelAPI_ResultPart::getSubShapeColor ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
pure virtual
Get subshape color.
◆ getColoredSubShapes()
virtual void ModelAPI_ResultPart::getColoredSubShapes ( std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &  theColoredShapes)
pure virtual
◆ removeSubShapeColors()
virtual void ModelAPI_ResultPart::removeSubShapeColors ( )
pure virtual
◆ combineGeometrical()
virtual bool ModelAPI_ResultPart::combineGeometrical ( const int  theIndex,
std::wstring &  theNewName
pure virtual
◆ selectionValue()
virtual std::shared_ptr< GeomAPI_Shape > ModelAPI_ResultPart::selectionValue ( const int  theIndex)
pure virtual
◆ updateShape()
virtual void ModelAPI_ResultPart::updateShape ( )
pure virtual
◆ selection()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ModelAPI_ResultPart::selection ( )
pure virtual
◆ loadPart()
virtual void ModelAPI_ResultPart::loadPart ( )
pure virtual
◆ COLOR_ID()
static const std::string & ModelAPI_Result::COLOR_ID ( )
inlinestaticinherited
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
◆ DEFLECTION_ID()
static const std::string & ModelAPI_Result::DEFLECTION_ID ( )
The double value is used. The value is in [0, 1] range
◆ TRANSPARENCY_ID()
static const std::string & ModelAPI_Result::TRANSPARENCY_ID ( )
◆ ISO_LINES_ID()
static const std::string & ModelAPI_Result::ISO_LINES_ID ( )
◆ SHOW_ISO_LINES_ID()
static const std::string & ModelAPI_Result::SHOW_ISO_LINES_ID ( )
◆ SHOW_EDGES_DIRECTION_ID()
static const std::string & ModelAPI_Result::SHOW_EDGES_DIRECTION_ID ( )
◆ BRING_TO_FRONT_ID()
static const std::string & ModelAPI_Result::BRING_TO_FRONT_ID ( )
The bool value is used.
◆ isConcealed()
bool ModelAPI_Result::isConcealed ( )
◆ setIsConcealed()
void ModelAPI_Result::setIsConcealed ( const bool  theValue,
const bool  theForced = false
Reimplemented in Model_ResultBody, and Model_ResultConstruction.
◆ setDisabled()
bool ModelAPI_Result::setDisabled ( std::shared_ptr< ModelAPI_Result >  theThis,
const bool  theFlag
The disabled result does not participate in any calculation and visualization: like it was removed. But it keeps the general parameters: colors, visibility, etc.
theThispointer to this object, needed to generate all events if it is necessary
theFlagmakes disabled if it is true
Reimplemented in Model_ResultBody, and Model_ResultPart.
◆ isDisabled()
bool ModelAPI_Result::isDisabled ( )
◆ initAttributes()
void ModelAPI_Result::initAttributes ( )
Reimplemented in Model_ResultBody, Model_ResultParameter, Model_ResultPart, and ModelAPI_ResultParameter.
◆ shape()
std::shared_ptr< GeomAPI_Shape > ModelAPI_Result::shape ( )
Reimplemented in Model_ResultConstruction, Model_ResultField, Model_ResultGroup, Model_ResultPart, and ModelAPI_ResultBody.
◆ vertices()
ListOfShape ModelAPI_Result::vertices ( const bool  theOnlyUnique = false)
◆ edges()
ListOfShape ModelAPI_Result::edges ( const bool  theOnlyUnique = false)
◆ wires()
ListOfShape ModelAPI_Result::wires ( const bool  theOnlyUnique = false)
◆ faces()
ListOfShape ModelAPI_Result::faces ( const bool  theOnlyUnique = false)
◆ shells()
ListOfShape ModelAPI_Result::shells ( const bool  theOnlyUnique = false)
◆ solids()
ListOfShape ModelAPI_Result::solids ( const bool  theOnlyUnique = false)
◆ attributeChanged()
void ModelAPI_Result::attributeChanged ( const std::string &  theID)
◆ init()
void ModelAPI_Result::init ( )
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ document()
std::shared_ptr< ModelAPI_Document > ModelAPI_Object::document ( ) const
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
◆ colorConfigInfo()
std::string &  ,
std::string &
inlinevirtualinherited
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ erase()
void ModelAPI_Object::erase ( )
◆ emptyFunction()
◆ myIsDisabled
bool ModelAPI_Result::myIsDisabled
