Extra API for the ResultBody that allows to work with naming. More...
#include <ModelAPI_BodyBuilder.h>
| virtual void | store (const GeomShapePtr &theShape, const bool theIsStoreSameShapes=true)=0 |
| Stores the shape (called by the execution method). More... | |
| virtual void | storeGenerated (const GeomShapePtr &theFromShape, const GeomShapePtr &theToShape, const bool theIsCleanStored=true)=0 |
| Stores the generated shape (called by the execution method). More... | |
| virtual void | storeGenerated (const std::list< GeomShapePtr > &theFromShapes, const GeomShapePtr &theToShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)=0 |
| Stores the root generated shapes (called by the execution method). More... | |
| virtual void | storeModified (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const bool theIsCleanStored=true)=0 |
| Stores the modified shape (called by the execution method). More... | |
| virtual void | storeModified (const std::list< GeomShapePtr > &theOldShapes, const GeomShapePtr &theNewShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)=0 |
| Stores the root modified shapes (called by the execution method). More... | |
| virtual GeomShapePtr | shape ()=0 |
| Returns the shape-result produced by this feature. More... | |
| virtual bool | generated (const GeomShapePtr &theNewShape, const std::string &theName, const bool theCheckIsInResult=true)=0 |
| Records the subshape newShape which was generated during a topological construction. More... | |
| virtual void | generated (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="")=0 |
| Records the shape newShape which was generated from the shape oldShape during a topological construction. More... | |
| virtual void | modified (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="")=0 |
| Records the shape newShape which is a modification of the shape oldShape. More... | |
| virtual void | loadDeletedShapes (const GeomMakeShapePtr &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const GeomShapePtr &theShapesToAvoid=GeomShapePtr())=0 |
| load deleted shapes More... | |
| virtual void | loadModifiedShapes (const GeomMakeShapePtr &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="")=0 |
| load and orient modified shapes More... | |
| virtual void | loadGeneratedShapes (const GeomMakeShapePtr &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="", const bool theSaveOldIfNotInTree=false)=0 |
| load and orient generated shapes More... | |
| virtual void | loadFirstLevel (GeomShapePtr theShape, const std::string &theName)=0 |
| load shapes of the first level (to be used during shape import) More... | |
| virtual MODELAPI_EXPORT void | cleanCash ()=0 |
| Cleans cash related to the already stored elements. More... | |
| virtual MODELAPI_EXPORT std::shared_ptr< ModelAPI_Data > | data () const |
| virtual MODELAPI_EXPORT std::shared_ptr< ModelAPI_Document > | document () const |
| MODELAPI_EXPORT | ModelAPI_BodyBuilder (ModelAPI_Object *theOwner) |
| Default constructor accessible only from Model_Object. More... | |
Protected Attributes | |
| ModelAPI_Object * | myOwner |
| the owner object this builder belongs to More... | |
protected |
pure virtual |
Implemented in Model_BodyBuilder.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
As an example, consider the case of a face generated in construction of a box. Returns true if it is stored correctly (the final shape contains this new sub-shape)
pure virtual |
As an example, consider the case of a face generated from an edge in construction of a prism.
pure virtual |
As an example, consider the case of a face split or merged in a Boolean operation.
pure virtual |
load deleted shapes
pure virtual |
pure virtual |
pure virtual |
pure virtual |
protectedvirtual |
protectedvirtual |
protected |
