ModelAPI_BodyBuilder.h
20#ifndef ModelAPI_BodyBuilder_H_
21#define ModelAPI_BodyBuilder_H_
23#include <ModelAPI.h>
24#include <GeomAPI_Shape.h>
25#include <GeomAlgoAPI_MakeShape.h>
26#include <GeomAPI_DataMapOfShapeShape.h>
27#include <memory>
28#include <string>
30class ModelAPI_Data;
32class ModelAPI_Object;
33
39{
40public:
41 MODELAPI_EXPORT virtual ~ModelAPI_BodyBuilder() {};
42
44 virtual void store(const GeomShapePtr& theShape,
45 const bool theIsStoreSameShapes = true) = 0;
46
48 virtual void storeGenerated(const GeomShapePtr& theFromShape,
49 const GeomShapePtr& theToShape,
50 const bool theIsCleanStored = true) = 0;
51
53 virtual void storeGenerated(const std::list<GeomShapePtr>& theFromShapes,
54 const GeomShapePtr& theToShape, const std::shared_ptr<GeomAlgoAPI_MakeShape> theMakeShape) = 0;
55
57 virtual void storeModified(const GeomShapePtr& theOldShape,
58 const GeomShapePtr& theNewShape,
59 const bool theIsCleanStored = true) = 0;
60
62 virtual void storeModified(const std::list<GeomShapePtr>& theOldShapes,
63 const GeomShapePtr& theNewShape, const std::shared_ptr<GeomAlgoAPI_MakeShape> theMakeShape)=0;
64
66 virtual GeomShapePtr shape() = 0;
67
71 virtual bool generated(const GeomShapePtr& theNewShape,
72 const std::string& theName, const bool theCheckIsInResult = true) = 0;
73
77 virtual void generated(const GeomShapePtr& theOldShape,
78 const GeomShapePtr& theNewShape,
79 const std::string& theName = "") = 0;
80
83 virtual void modified(const GeomShapePtr& theOldShape,
84 const GeomShapePtr& theNewShape,
85 const std::string& theName = "") = 0;
86
88 virtual void loadDeletedShapes(const GeomMakeShapePtr& theAlgo,
89 const GeomShapePtr& theOldShape,
90 const GeomAPI_Shape::ShapeType theShapeTypeToExplore,
91 const GeomShapePtr& theShapesToAvoid = GeomShapePtr()) = 0;
92
94 virtual void loadModifiedShapes(const GeomMakeShapePtr& theAlgo,
95 const GeomShapePtr& theOldShape,
96 const GeomAPI_Shape::ShapeType theShapeTypeToExplore,
97 const std::string& theName = "") = 0;
98
100 virtual void loadGeneratedShapes(const GeomMakeShapePtr& theAlgo,
101 const GeomShapePtr& theOldShape,
102 const GeomAPI_Shape::ShapeType theShapeTypeToExplore,
103 const std::string& theName = "",
104 const bool theSaveOldIfNotInTree = false) = 0;
105
107 virtual void loadFirstLevel(GeomShapePtr theShape,
108 const std::string& theName) = 0;
109
111 MODELAPI_EXPORT virtual void cleanCash() = 0;
112
113protected:
115 MODELAPI_EXPORT virtual std::shared_ptr<ModelAPI_Data> data() const;
116
118 MODELAPI_EXPORT virtual std::shared_ptr<ModelAPI_Document> document() const;
119
120protected:
122 MODELAPI_EXPORT ModelAPI_BodyBuilder(ModelAPI_Object* theOwner);
123
125};
126
128typedef std::shared_ptr<ModelAPI_BodyBuilder> BodyBuilderPtr;
129
130#endif
ShapeType
Shape type enum.
Definition: GeomAPI_Shape.h:46
Extra API for the ResultBody that allows to work with naming.
Definition: ModelAPI_BodyBuilder.h:39
virtual void loadFirstLevel(GeomShapePtr theShape, const std::string &theName)=0
load shapes of the first level (to be used during shape import)
virtual bool generated(const GeomShapePtr &theNewShape, const std::string &theName, const bool theCheckIsInResult=true)=0
Records the subshape newShape which was generated during a topological construction.
virtual GeomShapePtr shape()=0
Returns the shape-result produced by this feature.
virtual void storeGenerated(const GeomShapePtr &theFromShape, const GeomShapePtr &theToShape, const bool theIsCleanStored=true)=0
Stores the generated shape (called by the execution method).
virtual void loadDeletedShapes(const GeomMakeShapePtr &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const GeomShapePtr &theShapesToAvoid=GeomShapePtr())=0
load deleted shapes
ModelAPI_Object * myOwner
the owner object this builder belongs to
Definition: ModelAPI_BodyBuilder.h:124
virtual void storeGenerated(const std::list< GeomShapePtr > &theFromShapes, const GeomShapePtr &theToShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)=0
Stores the root generated shapes (called by the execution method).
virtual MODELAPI_EXPORT std::shared_ptr< ModelAPI_Data > data() const
Definition: ModelAPI_BodyBuilder.cpp:28
virtual void loadModifiedShapes(const GeomMakeShapePtr &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="")=0
load and orient modified shapes
virtual void modified(const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="")=0
Records the shape newShape which is a modification of the shape oldShape.
virtual void storeModified(const std::list< GeomShapePtr > &theOldShapes, const GeomShapePtr &theNewShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape)=0
Stores the root modified shapes (called by the execution method).
virtual void store(const GeomShapePtr &theShape, const bool theIsStoreSameShapes=true)=0
Stores the shape (called by the execution method).
virtual MODELAPI_EXPORT void cleanCash()=0
Cleans cash related to the already stored elements.
virtual MODELAPI_EXPORT std::shared_ptr< ModelAPI_Document > document() const
Definition: ModelAPI_BodyBuilder.cpp:33
virtual void storeModified(const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const bool theIsCleanStored=true)=0
Stores the modified shape (called by the execution method).
MODELAPI_EXPORT ModelAPI_BodyBuilder(ModelAPI_Object *theOwner)
Default constructor accessible only from Model_Object.
Definition: ModelAPI_BodyBuilder.cpp:23
virtual void loadGeneratedShapes(const GeomMakeShapePtr &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="", const bool theSaveOldIfNotInTree=false)=0
load and orient generated shapes
virtual void generated(const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="")=0
Records the shape newShape which was generated from the shape oldShape during a topological construct...
General object of the application that allows to get/set attributes from the document and compute res...
Definition: ModelAPI_Data.h:73
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
