ExchangePlugin_Dump.h
20#ifndef EXCHANGEPLUGIN_DUMP_H_
21#define EXCHANGEPLUGIN_DUMP_H_
23#include <ExchangePlugin.h>
24
26
33{
34public:
36 inline static const std::string& ID()
37 {
38 static const std::string MY_DUMP_ID("Dump");
39 return MY_DUMP_ID;
40 }
42 inline static const std::string& DUMP_DIR_ID()
43 {
44 static const std::string MY_DUMP_DIR_ID("dump_dir");
45 return MY_DUMP_DIR_ID;
46 }
48 inline static const std::string& FILE_PATH_ID()
49 {
50 static const std::string MY_FILE_PATH_ID("file_path");
51 return MY_FILE_PATH_ID;
52 }
54 inline static const std::string& FILE_FORMAT_ID()
55 {
56 static const std::string MY_FILE_FORMAT_ID("file_format");
57 return MY_FILE_FORMAT_ID;
58 }
59
61 inline static const std::string& TOPOLOGICAL_NAMING_DUMP_ID()
62 {
63 static const std::string MY_TOOPNAMING_DUMP_ID("topological_naming");
64 return MY_TOOPNAMING_DUMP_ID;
65 }
67 inline static const std::string& GEOMETRIC_DUMP_ID()
68 {
69 static const std::string MY_GEOM_DUMP_ID("geometric_selection");
70 return MY_GEOM_DUMP_ID;
71 }
72
74 inline static const std::string& WEAK_NAMING_DUMP_ID()
75 {
76 static const std::string MY_WEAK_NAMING_DUMP_ID("weak_naming");
77 return MY_WEAK_NAMING_DUMP_ID;
78 }
79
81 inline static const std::string& EXPORT_VARIABLES_ID()
82 {
83 static const std::string MY_EXPORT_VARIABLES_ID("export_variables");
84 return MY_EXPORT_VARIABLES_ID;
85 }
86
88 inline static const std::string& MULTIFILE_ID()
89 {
90 static const std::string MY_MULTIFILE_ID("is_multifile");
91 return MY_MULTIFILE_ID;
92 }
93
95 EXCHANGEPLUGIN_EXPORT ExchangePlugin_Dump();
97 EXCHANGEPLUGIN_EXPORT virtual ~ExchangePlugin_Dump();
98
100 EXCHANGEPLUGIN_EXPORT virtual const std::string& getKind()
101 {
103 }
104
106 EXCHANGEPLUGIN_EXPORT virtual void initAttributes();
107
109 EXCHANGEPLUGIN_EXPORT virtual void execute();
110
112 EXCHANGEPLUGIN_EXPORT virtual bool isMacro() const { return true; }
113
115 EXCHANGEPLUGIN_EXPORT virtual bool isPreviewNeeded() const { return false; }
116
117protected:
119 EXCHANGEPLUGIN_EXPORT void dump(const std::string& theFileName);
120};
121
122#endif
Store full model as a Python script.
Definition: ExchangePlugin_Dump.h:33
virtual EXCHANGEPLUGIN_EXPORT void initAttributes()
Definition: ExchangePlugin_Dump.cpp:62
virtual EXCHANGEPLUGIN_EXPORT const std::string & getKind()
Returns the unique kind of a feature.
Definition: ExchangePlugin_Dump.h:100
virtual EXCHANGEPLUGIN_EXPORT bool isMacro() const
Reimplemented from ModelAPI_Feature::isMacro(). Returns true.
Definition: ExchangePlugin_Dump.h:112
static const std::string & FILE_PATH_ID()
attribute name of file path
Definition: ExchangePlugin_Dump.h:48
virtual EXCHANGEPLUGIN_EXPORT bool isPreviewNeeded() const
Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false.
Definition: ExchangePlugin_Dump.h:115
static const std::string & WEAK_NAMING_DUMP_ID()
attribute name of dumping by using weak naming identifiers of selection
Definition: ExchangePlugin_Dump.h:74
Default constructor.
Definition: ExchangePlugin_Dump.cpp:54
EXCHANGEPLUGIN_EXPORT void dump(const std::string &theFileName)
Performs dump to the file.
Definition: ExchangePlugin_Dump.cpp:97
virtual EXCHANGEPLUGIN_EXPORT void execute()
Computes or recomputes the results.
Definition: ExchangePlugin_Dump.cpp:86
Feature kind.
Definition: ExchangePlugin_Dump.h:36
static const std::string & DUMP_DIR_ID()
attribute name of true dumping directory
Definition: ExchangePlugin_Dump.h:42
static const std::string & EXPORT_VARIABLES_ID()
attribute name for boolean flag to export variable names correspondence to another module
Definition: ExchangePlugin_Dump.h:81
static const std::string & TOPOLOGICAL_NAMING_DUMP_ID()
attribute name of dumping by topological naming
Definition: ExchangePlugin_Dump.h:61
static const std::string & GEOMETRIC_DUMP_ID()
attribute name of dumping by geometric selection
Definition: ExchangePlugin_Dump.h:67
virtual EXCHANGEPLUGIN_EXPORT ~ExchangePlugin_Dump()
Default destructor.
Definition: ExchangePlugin_Dump.cpp:58
static const std::string & FILE_FORMAT_ID()
attribute name of file format
Definition: ExchangePlugin_Dump.h:54
static const std::string & MULTIFILE_ID()
attribute name for multifile dump
Definition: ExchangePlugin_Dump.h:88
