GeomDataAPI_Dir Class Referenceabstract
Attribute that contains 3D direction coordinates. More...
#include <GeomDataAPI_Dir.h>
Inheritance diagram for GeomDataAPI_Dir:
virtual void setValue (const double theX, const double theY, const double theZ)=0
 Defines the double value. More...
virtual void setValue (const std::shared_ptr< GeomAPI_Dir > &theDir)=0
 Defines the direction. More...
virtual double x () const =0
 Returns the X double value. More...
virtual double y () const =0
 Returns the Y double value. More...
virtual double z () const =0
 Returns the Z double value. More...
virtual std::shared_ptr< GeomAPI_Dir > dir ()=0
 Returns the direction of this attribute. More...
virtual std::shared_ptr< GeomAPI_XYZ > xyz ()=0
 Returns the coordinates of this attribute. More...
virtual std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 GeomDataAPI_Dir ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ GeomDataAPI_Dir()
GeomDataAPI_Dir::GeomDataAPI_Dir ( )
◆ setValue() [1/2]
virtual void GeomDataAPI_Dir::setValue ( const double  theX,
const double  theY,
const double  theZ
pure virtual
Implemented in GeomData_Dir.
◆ setValue() [2/2]
virtual void GeomDataAPI_Dir::setValue ( const std::shared_ptr< GeomAPI_Dir > &  theDir)
pure virtual
◆ x()
virtual double GeomDataAPI_Dir::x ( ) const
pure virtual
◆ y()
virtual double GeomDataAPI_Dir::y ( ) const
pure virtual
◆ z()
virtual double GeomDataAPI_Dir::z ( ) const
pure virtual
◆ dir()
virtual std::shared_ptr< GeomAPI_Dir > GeomDataAPI_Dir::dir ( )
pure virtual
◆ xyz()
virtual std::shared_ptr< GeomAPI_XYZ > GeomDataAPI_Dir::xyz ( )
pure virtual
◆ typeId()
static std::string GeomDataAPI_Dir::typeId ( )
inlinestatic
◆ attributeType()
std::string GeomDataAPI_Dir::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
