ModelAPI_AttributeDoubleArray Class Referenceabstract
API for the attribute that contains several double in the array inside. More...
#include <ModelAPI_AttributeDoubleArray.h>
Inheritance diagram for ModelAPI_AttributeDoubleArray:
virtual MODELAPI_EXPORT int size ()=0
 Returns the size of the array (zero means that it is empty) More...
virtual MODELAPI_EXPORT void setSize (const int theSize)=0
 Sets the new size of the array. The previous data is erased. More...
virtual MODELAPI_EXPORT void setValue (const int theIndex, const double theValue)=0
 Defines the value of the array by index [0; size-1]. More...
virtual MODELAPI_EXPORT double value (const int theIndex)=0
 Returns the value by the index. More...
virtual MODELAPI_EXPORT std::string attributeType ()
virtual MODELAPI_EXPORT ~ModelAPI_AttributeDoubleArray ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static MODELAPI_EXPORT std::string typeId ()
MODELAPI_EXPORT ModelAPI_AttributeDoubleArray ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ~ModelAPI_AttributeDoubleArray()
ModelAPI_AttributeDoubleArray::~ModelAPI_AttributeDoubleArray ( )
◆ ModelAPI_AttributeDoubleArray()
ModelAPI_AttributeDoubleArray::ModelAPI_AttributeDoubleArray ( )
◆ size()
virtual MODELAPI_EXPORT int ModelAPI_AttributeDoubleArray::size ( )
pure virtual
Implemented in Model_AttributeDoubleArray.
◆ setSize()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDoubleArray::setSize ( const int  theSize)
pure virtual
◆ setValue()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDoubleArray::setValue ( const int  theIndex,
pure virtual
◆ value()
virtual MODELAPI_EXPORT double ModelAPI_AttributeDoubleArray::value ( const int  theIndex)
pure virtual
◆ typeId()
static MODELAPI_EXPORT std::string ModelAPI_AttributeDoubleArray::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeDoubleArray::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
